tl aspec suspension into accord V6 - Honda Accord Forum : V6 Performance Accord Forums
Old May 7th, 2014, 03:13 PM   #1
snipeer's Avatar
i am looking hard to get HFP suspension for my V6 03 Accord coupe. i would like to know if aspec suspesnion from 07-08 tl would a good choice to put by replacing the top hats (if required) any input will be appreciated
snipeer is offline   Reply With Quote Quick reply to this message
Old May 8th, 2014, 12:33 PM   #2
03 AV6 Coupe
hondav6's Avatar
I had that exact setup. I had a 06 TL A spec suspension on my 03 accord v6. All you need to do is replace the top hats with your stock ones. IMO, i wouldnt go that route. I much prefer my eibach pro kit and koni yellow setup. It is much better.
2003 Honda Accord EX V6 Coupe
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
Innovative 60A Mounts
Koni Yellows/Eibach Pro Kit
TL-S Rear Sway Bar
Neuspeed Strut Bar
Old May 9th, 2014, 08:57 AM   #3
snipeer's Avatar
thanks for your reply, i currently have Neuspeed sports spring with oem shocks. car currently have 77K miles. i was looking into more oem stuff than going with after market. as its hard to get HFP now i thought about aspec suspension. but i guess i should stay with what i have and go with yours or other aftermarket options. thanks again for your reply
Old May 10th, 2014, 07:43 PM   #4
03 AV6 Coupe
hondav6's Avatar
No problem man. The setup I have feels great. It is very much like what honda should have done with the accord coupe v6. The ride quality is still awesome. It also feels more planted to the road. Whatever you do, don't stick with OEM shocks and aftermarket springs. They aren't meant to go together. Stick with your neuspeed springs and go with a KYB shock, Tokiko or the Koni yellows. You will be amazed with the difference. That will save you some money. Or go back to OEM springs with aftermarket shocks. Better than the setup you have for sure. Good luck!
Injen CAI
Magnaflow CBE
UR Pulley
Richie's V3 J-Pipe
J35 Magnesium IM
MDX IM Spacer
P2R Thermal Gaskets
TB Coolant Bypass
TL-S Rear Sway Bar
Neuspeed Strut Bar
