Bagged 2003 Coupe - Honda Accord Forum : V6 Performance Accord Forums
Old March 3rd, 2004, 04:39 PM   #1
Rolling on 19's
00&03Accords's Avatar
Bagged 2003 Coupe
For those of you thinking of baggin your accords here is a new product coming out. Its an air strut instead of the air cylinder, this means a smoother ride, sometimes better than stock at the right psi.
And the Acura TSX
http://www.airrunner.co.jp/index.htm
THAT IS NOT MY CAR........
00&03Accords is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2004, 05:18 PM   #2
Uber rice. Why not just mount the wheels on the roof?
Snatchface is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2004, 05:22 PM   #3
DeezNutz972's Avatar
Send a message via AIM to DeezNutz972
hows that rice? that looks sweet!
how much does a kit like that run for? $$$
and are the tanks really heavy?
DeezNutz972 is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2004, 06:12 PM   #4
I see nothing rice about that... Anyone know how much that costs? I think it looks real good and would like to have a set-up like that. Hopefully its not way over-priced because I have been considering going with air and was looking for a bolt on kit like this one.
II six speed II is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2004, 06:20 PM   #5
bryan <3's bomex
mastadulog's Avatar
He just wants to act like a "cool guy" because the cool thing to do nowadays is to label something rice
-97 Accord V6-
aim: bpdulog
photos:
myspace:
hincity:
Old March 3rd, 2004, 06:50 PM   #6
Chicago Moderator
Send a message via ICQ to Bbc84 Send a message via AIM to Bbc84
Anything for the 6th gens?
Bbc84 is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2004, 07:04 PM   #7
Rolling on 19's
A kit like that will probably be around 2k. It is straight bolt on. The tanks will probably weight like 10-15 lbs depending on the size of them.
Old March 3rd, 2004, 07:09 PM   #8
Well I may go with that over the teins. 19" Racing Hart C5s + Airbagged= droooooool
JPAccord is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2004, 07:12 PM   #9
Chicago Moderator
Hmm i see they have a kit for 99-03 TL
i wonder if thats transferable to the 6th gen sedan. hehehe
Old March 3rd, 2004, 07:18 PM   #10
dam...2k?? how is the reliability of these systems?
on this kit im guessing you just take out your struts/springs and replace it with this kit?
Old March 3rd, 2004, 07:26 PM   #11
AV6.com Veteran
that looks TOO good!
kayotik is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2004, 07:28 PM   #12
that's euro version?
ADDICTED2ICELED is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2004, 07:39 PM   #13
Old Member
Du3ce's Avatar
damn thats dope
Old March 3rd, 2004, 07:59 PM   #14
Rolling on 19's
Yeah its a straight replacement, the reliability depends on the user. If you abuse it and dont give it proper maintenance then they will not last. Also, i do not recommend having only one compressor. I had 4 on my car. Not just for back up but for a fast re-fill of my tanks to clown around
Old March 3rd, 2004, 08:12 PM   #15
7th Gen ACcord
xjdMb16a2six's Avatar
damn that looks fuking sexyyyyy. i fuking dig ittttt
Old March 3rd, 2004, 08:27 PM   #16
so u have to refill the air every once in a while? otherwise it wont go back up? dam. is this a freindly system for daily driving?
Current: 2007 Accord Sedan V6 EX-L
Past: 2003 V6 Coupe & 2005 BMW M3
Old March 3rd, 2004, 08:33 PM   #17
00&03Accords: What kind of maintenance would those require exactly? Under regular use and maintenance, how long will they last. I have seen and heard of people with with air bags having problems at times, but I never heard anything bad about the struts.
Old March 3rd, 2004, 08:47 PM   #18
Rolling on 19's
This is how this works, you have a compressor that is connected to the tank. There is a pressure switch or relay that is set to a certain psi, once the tank goes below that point the compressor turns on and fills your tank back up. It only turns on if your car is on, if its off it will not. Unless they wire it differently.
Old March 3rd, 2004, 08:50 PM   #19
Rolling on 19's
I dont really know what kind of maintenance there is for struts, i know for cylinders you need to spray wd-40 to keep it lubricated. As far as other things to worry about are the compressors and the valves. Some valves stick with time, when that happends the air is not locked in the bag and it spits it back to the tank. There is a check valve that prevents it from spitting it back.
Old March 4th, 2004, 06:02 AM   #20
When you've lowered your car so much that the rear bumper is scraping the ground...that's rice. The one in his sig looks great. The TSX is just ridiculous.
Old March 4th, 2004, 09:07 AM   #21
^ I agree if you chop your spring and your car is scraping on the ground w/ no suspension then you can call it rice, Air Ride is definitly NOT rice! being able to get out of your car and slam it to the ground is F*CKIN HOT!
Old March 4th, 2004, 09:52 AM   #22
Hell yeah!!
*Note to self...get airbags*
AccordEXGirl is offline   Reply With Quote Quick reply to this message
Old March 4th, 2004, 10:10 AM   #23
does your handling really go to hell with bags? thats what ive heard, and besides the cost, that was another thing that was stopping me. is everything weird now, or are the bags pretty decent? i mean, decent enuff for being air bags.
Old March 7th, 2004, 10:38 PM   #24
7th Gen ACcord
^^^^ i doubt it. airbags are just for show.
Old March 7th, 2004, 11:48 PM   #25
mao
v6p gangster
mao's Avatar
Send a message via AIM to mao
hot ish!
mao is offline   Reply With Quote Quick reply to this message
Old March 8th, 2004, 01:38 PM   #26
Rolling on 19's
Handling sucks with air ride. No fast cornering because u will loose control of the car. At high speeds it feels really bad, like you can loose control and smack on the wall. I know hit around 110-115 on my 2000 accord on air and it felt really bad, had to slow let go of the gas.
Old March 8th, 2004, 02:51 PM   #27
y is that? is it just too bouncy at higher speeds?
Old September 19th, 2004, 08:26 AM   #28
Talking maybe not
EEK. Looks nice though. IMHO, good enough for parking-lot-pimpin'.
I prefer crazy man driving, I'll get the Teins.
7810_Accord04Co is offline   Reply With Quote Quick reply to this message
Old September 19th, 2004, 09:07 AM   #29
6th and BEST Generation
tool462's Avatar
Send a message via AIM to tool462
That looks sweet , not "rice" at all !!!!
tool462 is offline   Reply With Quote Quick reply to this message
Old September 19th, 2004, 11:31 PM   #30
the tooth
Damnnn only if i had the money........ dROOL... BTW, how was that rice again?
Timmy is offline   Reply With Quote Quick reply to this message
