Need help with wheel choice - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By HonDERS
Old August 25th, 2014, 08:22 AM   #1
Hello group, I originally posted this in one of the wheel threads but that thread seemed more for showing off your wheels so I posted a new one.
Im trying to help my daughter out, she is 17 and wants a set of wheels for her stock 04 Accord sedan. I dont know much about aftermarket wheel fitment so I thought I would ask for some help.
She found a set of wheels she likes and the size is Size: 16x7
Bolt Pattern: 5x100/114.3 Offset: +38mm. From what I found, the only difference is the offset as the stock is 55mm ( I think). I assume that would just make the wheel stick out 17mm more than stock? Would there be any issue in just bolting these up with the stock tire size of 205/60/16?
Thanks for helping me out!
Dave
Penman is offline   Reply With Quote Quick reply to this message
Old August 25th, 2014, 08:37 AM   #2
accord325's Avatar
^ wasn't aware that 7th gens came with 16" rims.
You will be fine. I don't see anything that would make it come even close to rubbing. I would personally put 17" or 18's on there. Seems like 16's would leave a massive gap.
Old August 25th, 2014, 08:56 AM   #3
^ probably has a cyl. No problem with the 38mm offset. What is the width of the rim? 7? 8?
Old August 25th, 2014, 09:35 AM   #4
accord325's Avatar
^ it's in the OP 16x7. All I can imagine is gap all around, but I'm turning into a Slammed obsessed person, with a hatred for Wheel gap. LOL
These specs dont even come close to having issues. Hell, On Tein Springs I had 19x8's with 235 tires and didn't touch my fenders.
Old August 25th, 2014, 12:43 PM   #5
Thanks for all your advice, like I said this really isn't my thing. Is there a guide on this forum or somewhere on the web that can give me an idea on the tire size that I could put on there if I were to go with a 17 or 18 inch wheel?
Old August 25th, 2014, 01:00 PM   #6
go with 17 x 7 since the tire for it are fair cheap. check out discount tire direct they have a deal going on if you buy wheel and tires from them.
Old August 25th, 2014, 01:43 PM   #7
deffs would go 18 or 17 at the very least.
offset can vary but 35-40 will be fine
rave93 is offline   Reply With Quote Quick reply to this message
Old August 25th, 2014, 01:55 PM   #8
Any suggestions on tire size with the 17's?
Old August 25th, 2014, 03:13 PM   #9
215 50 17 if you want the speedo to be fairly accurate. that what it comes with stock.
Old August 25th, 2014, 04:31 PM   #10
HonDERS's Avatar
Autos come with 205/60/16 stock. Source: I have an autotragic tranny.
HonDERS is offline   Reply With Quote Quick reply to this message
Old August 25th, 2014, 04:51 PM   #11
Honda enthusiast
michaellowrider's Avatar
You're a cool dad! I also suggest going bigger, it will look better. Also lowering it will dramatically improve the looks. What wheels does she like?
Old August 25th, 2014, 04:53 PM   #12
true but he wanted 17in rims
Old August 25th, 2014, 05:01 PM   #13
HonDERS's Avatar
I understand now, my bad. I'll shut up.
thisaznboi88 likes this.
