endlink bolt, help! - Honda Accord Forum : V6 Performance Accord Forums
Old March 13th, 2004, 09:22 AM   #1
endlink bolt, help!
Hi,
I got my rear sway and I started installing. I put my hex key to the endlink and as I was loosening the bolt my hex key broke. The bolt is loose, broken hex key's inside and I cannot get the bolt out. What should I do? Is there any good way to get this? Thanks.
dlee27 is offline   Reply With Quote Quick reply to this message
Old March 13th, 2004, 09:52 AM   #2
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
Wow..... that sux.
Is there any sticking out that you can grab with vise grips? Probably not, I imagine....... that's too easy.
Hex keys are normally hardened, so it would be tough to drill it out.
I don't know...... hopefully somebody esle will have an idea.
Good luck.
Old March 13th, 2004, 10:21 AM   #3
Senior Moderhater
abram2001's Avatar
The best advice I can give is this....
Since the the hex key is inside of the threaded bolt, use a lighter to heat up the OUTSIDE of the thread. This will make the OUTSIDE metal expand, then get a magnet, or some sort of tweezers to pull out the embedded hex.... dont forget about some WD-40. Good Luck, let me know what happens.
BTW, you dont need to get a new hex set, there is a long hex tool in the trunk with the jack, and it fits in there perfectly
Old March 13th, 2004, 10:29 AM   #4
Re: endlink bolt, help!
Originally posted by dlee27
Hi,
You might try grabbing the bolt from behind the endlink connection. This is a bad drawing, but it gives you the idea. I had a similar thing happen to me...the hex stripped out.
http://www.v6performance.net/gallery...nk_diagram.JPG
03Accord is offline   Reply With Quote Quick reply to this message
Old March 13th, 2004, 10:21 PM   #5
Thanks everyone. I tried for a while to no avail so I just let the shop do it. I didn't want to make it worse. Anyway, it's all good now.
I later found this out. That sunroof tool is exactly 5mm.
http://www.v6performance.net/galler...ink_diagram.JPG
I didn't know that I can grab from the other side. I should have tried this. Anyway, Thanks.
Old March 13th, 2004, 10:25 PM   #6
Where is this 5mm tool?
Illusion-Lighting is offline   Reply With Quote Quick reply to this message
Old March 13th, 2004, 11:25 PM   #7
That long hex key is used to close the sunroof manually. It's in the trunk with the other tools.
