07 TLS front sway bar in 7th gen problems - Honda Accord Forum : V6 Performance Accord Forums
Old June 7th, 2015, 03:57 PM   #1
bozos_si's Avatar
I recently put in a 07 TLS front sway bar. After doing this I now hear clunking noises coming from the front end when turning into an incline.This happens every time turning into my alley. Its not even that steep of an incline. Its bad enough that I can feel it on the floor of the car. Has anyone else experienced this problem? I put in polyurethane bushings and used oem 7th gen sway bar links.
Old June 24th, 2015, 05:54 AM   #2
What about rear from tls?
sasa is offline   Reply With Quote Quick reply to this message
Old June 24th, 2015, 05:55 AM   #3
May be smome dust in bushings
Old July 2nd, 2015, 11:35 PM   #4
Mr. Detail
Scottwax's Avatar
Sounds like something is loose. Have you checked the D-bushings, end links and the subframe bolts (assuming you loosened them to swap out the bar)?
Old July 2nd, 2015, 11:54 PM   #5
J30 LSD
flylow2cre8's Avatar
compliance bushing going?
Old July 3rd, 2015, 07:41 AM   #6
Check for contact with the end links
My rear TLS and Moog endlinks are making contact with my coilovers causing clunking.
Old August 1st, 2015, 02:03 PM   #7
jjhuffyo's Avatar
OP - still having problem or did you find out what was causing this?
I have the same sway bars (front and back) from the TL Type-S and haven't heard any noises like that.
jjhuffyo is offline   Reply With Quote Quick reply to this message
