2003 Accord Squeaking Noise on Turns and Bumps - Honda Accord Forum : V6 Performance Accord Forums
Old September 15th, 2015, 12:31 AM   #1
I have an 03 accord ex 4 cylinder.
The front left wheel just recently started making a squeaking noise when turning. It also squeaks sometimes over bumps. I believe it could be the lower ball joint. I changed the right lower ball joint but never the left one. I just wanna kno what u guys think. Also, the steering feels weird , as if it's wandering even when I'm holding it straight, which gives me more reason to believe it's a ball joint. Let me know what u guys think, thanks
Erod90 is offline   Reply With Quote Quick reply to this message
Old September 15th, 2015, 04:46 AM   #2
Does it squeak if you try to bounce the car up and down? Jack that wheel up, hold at 12:30 position and rock the wheel. If it's the ball joints, you'll hear and see them moving. Check the upper also. Hold the wheel at 3:15 and rock it. If it moves you should see the inner or outer tie rods
