Alignmemt - Honda Accord Forum : V6 Performance Accord Forums
Old March 30th, 2016, 04:31 PM   #1
Sleeper
NvrDwn's Avatar
Alignmemt
I had my car aligned back in maybe september. Maybe a month or two ago I notice when I back up my passenger front tire makes a screech sound and recently it makes that sound sometimes in either direction to about 25mph. I checked my tires and both have inside tire wear, the passenger is the worse by far.
I checked and pulled on everything with the car up and didn't notice anything.
I'm thinking maybe the ball bearing? Tie Rodso look fine to btw.
Old March 30th, 2016, 04:47 PM   #2
Toe is the cause of most excessive wear but you said the tie rods are fine. It could just be out of spec again.
My lower ball joints went around 155k. They had noticeable play up/down and made grinding noises when I turned.
Old April 2nd, 2016, 10:23 AM   #3
Sleeper
NvrDwn's Avatar
Both upper ball joints went out.. Luckily I have a garage, compressor, and a press. It'll take a little time to replace as I think the spring/shock needs to be moved away.
PCDS, Custom 3" exhaust, 3" HFC, 4" CAI, Polished ZDX TB, P&P Intake Manifold, P&P Runners, deleted butterfly valve, UDP, deleted a/c and p/s, 160lbs lighter, and smaller tires.
1/8th mile 9.06 @ 82.31
8's here I come.
Old April 3rd, 2016, 04:32 PM   #4
The Jester
Honestly while they're out, do the whole front bushing segments. New LCAs are about 100 for a pair on rockauto, front lower and upper ball joints can be had for about 150 combined, ish.
I know mevotech makes some good uppers that allow a bit of adjustment, and I had been looking at some proforged lower, well accepted as very good ball joints, 1million mile warranty.
Oh and the LCA lower bushings can be polyfilled before install for increased life.
Old April 3rd, 2016, 04:36 PM   #5
autozone has 3-five brand (555). they have lifetime warranty and are made in japan
thisaznboi88 is online now   Reply With Quote Quick reply to this message
Old April 12th, 2016, 10:56 AM   #6
I lowered my car on Tein Street Advanced Dampening Coilovers and once its been lowered, my car have been shaking/vibrating around 20mph then stops and become normal after that. Any ideas why?
BigBote is offline   Reply With Quote Quick reply to this message
Old April 12th, 2016, 11:39 AM   #7
Alignment is probably all jacked up. It feels jumppy right?
Old April 12th, 2016, 02:32 PM   #8
Like it shakes hard enough to make the passenger seat shake. Not really jumpy. My alignment is really bad tho so that may be that case. Im just waiting to get my tires mounted so i can finally get an alignment.
Old April 17th, 2016, 08:19 AM   #9
I put my wheels on and the shaking isnt that bad anymore. I just raised it up by 1/2 an inch. it still shakes but not as bad. almost to none
