Rear BBK Options - Honda Accord Forum : V6 Performance Accord Forums
Old April 7th, 2016, 05:39 PM   #1
Rear BBK Options
I have decided to get the Advics RL Calipers and 324x30 Rotors with the FastBrakes spacer and steel lines in the front. What are my options for upgrading the rear braking system in my 2003 Accord EX V6 Coupe?
Is there an upgraded caliper that I can install in the rear? Can I upgrade the rear rotors? What are all of my options? Will I need spacers in the rear also?
Thank you.
AccordFire is offline   Reply With Quote Quick reply to this message
Old April 7th, 2016, 06:52 PM   #2
MDX rotor and extended brackets
Old April 8th, 2016, 05:32 AM   #3
Carpe Diem
ikethegreat's Avatar
The extended bracket can also be found on fastbrakes.
Old April 9th, 2016, 09:29 PM   #4
So I would need 2 sets of brackets, one for the front, and one for the rear? If I use the MDX rotors in the rear, do I retain the stock calipers?
Old April 11th, 2016, 07:41 AM   #5
Carpe Diem
Yes, 2 sets of brackets, but the front brackets and rear brackets are different. Yes, you retain the stock calipers, they are just relocated to accommodate larger rotors.
