Is this the type of rear camber kit i need???? - Honda Accord Forum : V6 Performance Accord Forums
Old March 22nd, 2005, 03:43 PM   #1
Igotvtec04's Avatar
shox.com has Ingalls rear camber kit, that can adjust from - 1.5 to +3 degrees for $119. im installing tein basic on my 04 coupe V6, is that the kind of rear camber kit i need, is that the one you you can also adjust the toe??? I will be droping the rear 1.7". If you guys know any other place sells the same brand cheaper LET me know asap, before i place an order here.
Old March 22nd, 2005, 04:53 PM   #2
Igotvtec04's Avatar
I need a place i can get cheap Ingalls rear camber, the kind you can adjust camber/toe??
the cheapest one ive seen is from shox.com, but not sure if that camber and toe.
Old March 22nd, 2005, 05:42 PM   #3
ex scientia vera
kramer2k's Avatar
Try iapdirect.com. That's where I bought my SPC camber kit from.
Old March 22nd, 2005, 05:49 PM   #4
Igotvtec04's Avatar
but i heard ingalls is better, you can adjust both camber and toe
Old March 22nd, 2005, 05:50 PM   #5
ex scientia vera
kramer2k's Avatar
but i heard ingalls in better, you can adjust both camber and toe
They have that brand as well.
Old March 23rd, 2005, 04:57 AM   #6
Raddy21's Avatar
yeah who has best price on SPC Rear Camber for 7gens, thats what im tryin to do
Old March 23rd, 2005, 07:43 AM   #7
ex scientia vera
kramer2k's Avatar
I paid $144 shipped from iapdirect.com. They are offering free shipping and I used GBCSPC as the coupon code to get $5 off.
Old March 23rd, 2005, 11:19 AM   #8
Raddy21's Avatar
ok thanks kramer2k!
Old March 23rd, 2005, 12:31 PM   #9
i have spc camber for my rears...i paid 190 installed..
mofo. is offline   Reply With Quote Quick reply to this message
Old March 23rd, 2005, 01:33 PM   #10
Raddy21's Avatar
yes very cheap here ...hmm...
Old March 23rd, 2005, 01:52 PM   #11
Make Way for The Bad Guy!
JoeySmallz's Avatar
Send a message via AIM to JoeySmallz
Comptech has front and rear camber kits out for the 7th gen. also. That's what I'll be getting with by Tein SS
JoeySmallz is offline   Reply With Quote Quick reply to this message
Old March 23rd, 2005, 03:35 PM   #12
Send a message via AIM to macboi
there a guy that sells spc rear on ebay forlike 120$ shipped
macboi is offline   Reply With Quote Quick reply to this message
Old March 23rd, 2005, 03:37 PM   #13
SPC doesn't adjust toes? oh snap
Old March 23rd, 2005, 03:41 PM   #14
Igotvtec04's Avatar
the website (iapdirect.com) im ordering the ingalls is in backorder, but they have SPC, only camber can be adjusted. With Ingalls camber and toe, do i really need toe adjustment im only lowering the rear 1.7"?????
damn, shox.com is also out stock. Any other place you guys know???
Old March 24th, 2005, 02:21 PM   #15
Jinx32's Avatar
Do your research. Each side with the Ingalls kit requires the installation of 2 suspension arms, the lower arm and the control arm. You will need 2 kits to do both sides of the car, total of 4 bars to be installed. 1 kit runs about $130. See link and call your distributor for details before ordering, to make sure you don't end up with only enough parts to do one side of the car.
The Ingalls kit replaces the lower arm, pulling the bottom of the wheel in to adjust camber. But it pulls it back at a slight angle which affects the rear toe, so they also replace the mid/rear control arm to push the toe back into spec.
The SPC kit replaces only the upper arm, pushing the top of the wheel back out. It does not affect toe.
http://www.ingallseng.com/parts/38725.htm
J
Jinx32 is offline   Reply With Quote Quick reply to this message
Old March 24th, 2005, 02:31 PM   #16
Igotvtec04's Avatar
are you telling me that jinx? are you saying with out those two suspension arm the camber kit will be useless, and can not be installed.
i thought you only need camber kit nothing else. Im only lowering the back 1.7".
Old March 24th, 2005, 02:44 PM   #17
Jinx32's Avatar
Just posting in general for everyone to really look at what they are paying for. I've seen too many people pay $90 for a camber kit and only get the one side. Funny actually.
Regardless, I have HFP and SPC camber kit. There is a notch on the SPC kit in the threads that tells you how far you can safely twist it before you are too far. With the HFP kit, I eyeballed it to the length of the stock rod and it was already at the limit of how far you can adjust it. Seems like it needs more threads on mine. I think HFP was to lower the rear 1". I took it to one place for an alignment and they said it was out of adjustment, couldn't go any further and it's barely in spec. I took it to the dealership for alignment after that. I highlighted the instructions that state clearly not to twist it past that mark. They aligned the car with no problems. I am unsure if they went past "the mark" on the camber kit. Makes me nervous.
J
Old March 24th, 2005, 02:47 PM   #18
Out of my Mind, Somewhere
TooHypper's Avatar
Send a message via Yahoo to TooHypper
I got the SPC arms for $62 an arm, then I had Toby put them in.
TooHypper is offline   Reply With Quote Quick reply to this message
Old March 24th, 2005, 06:57 PM   #19
The Poker KING
Igotvtec04, you'll be okay, iapdirect.com states they cover both left and right
All Camber Kit Pricing Is For Both Left and Right Corners Unless Otherwise Specified
Old March 25th, 2005, 04:11 AM   #20
Igotvtec04's Avatar
jinx32 quoted,"Each side with the Ingalls kit requires the installation of 2 suspension arms,".......
is that with ingalls only???do i need the two suspension arms with SPC??
Old March 25th, 2005, 06:53 PM   #21
odk
odk's Avatar
Got my Ingalls kit (pair,four bars) from Mantaray Motorsport Racing in Calif. $132.96. Free shipping. Received in 1 week.
odk is offline   Reply With Quote Quick reply to this message
Old March 26th, 2005, 05:01 PM   #22
U a Ryder Or a Hater?
04rydah's Avatar
Send a message via AIM to 04rydah
im not even gettin one ... just get it aligned... with my 1.8" all around drop camber is not bad at all ... i dunno ... just get it aligned... tire wear is there but oh well ...
04rydah is offline   Reply With Quote Quick reply to this message
Old March 26th, 2005, 06:55 PM   #23
Igotvtec04's Avatar
you got a pics of your car, and could you also post your alignment result
Old March 26th, 2005, 07:12 PM   #24
04rydah's Avatar
will do
Old March 26th, 2005, 10:26 PM   #25
NightShift's Avatar
Send a message via AIM to NightShift
wow, i thought i finally had it figured out with the springs and camber.... now we got toe issues and suspension arms? now im confused...i'll never get my car lowered haha
NightShift is offline   Reply With Quote Quick reply to this message
