sways bar setup - Honda Accord Forum : V6 Performance Accord Forums
Old April 1st, 2005, 09:35 AM   #1
sways bar setup
i want to make sure i'm doing this setup right without any missing part. i'm planning to replace my rear sway with tl and this is the part number im ordering from http://www.acuraparts247.com. Can i just replace the rear and not the front? this is going to a stock springs/shock no HFP part. this upgrade is just for everyday driving. this is for a 2004 accord coupe v6 auto
52308-S3M-A00 HOLDER
52306-SEP-A11 BUSH, RR. STABILIZER HOLDER (20MM)
52300-SEP-A11 SPRING, RR. STABILIZER
RP V6 coupe is offline   Reply With Quote Quick reply to this message
Old April 1st, 2005, 09:44 AM   #2
indoctidiscant
OwAce's Avatar
Originally Posted by RP V6 coupe
i want to make sure i'm doing this setup right without any missing part. i'm planning to replace my rear sway with tl and this is the part number im ordering from http://www.acuraparts247.com. Can i just replace the rear and not the front? this upgrade is just for everyday driving.
YEP..no more posts for you. search TL Rear sway on this forum.
Old April 1st, 2005, 09:47 AM   #3
i did the research (find alot of info)and just want to varify it. i was wondering if there is going to be an issue if i don't replace the front sway bar (couldn't find info of front sway bar not being replace and being a problem)
Old April 1st, 2005, 10:34 AM   #4
indoctidiscant
OwAce's Avatar
absolutely no issue. unless you want the front to be stiffer as well. if u got 6 spd ur alright, if u dont got 6 spd spend 250 and get a stiffer front sway bar. (TL, or the 6spd or mebbe aftermkt)
Old April 1st, 2005, 10:38 AM   #5
ex scientia vera
kramer2k's Avatar
Hey LIL TANE....there's the info you were wanting BTW...
Old April 1st, 2005, 06:45 PM   #6
i have an auto and i don't think i will replace the front sway bar.
Old August 26th, 2005, 02:34 PM   #7
Master of Disaster...
MysterGoode's Avatar
Send a message via AIM to MysterGoode Send a message via MSN to MysterGoode
I know this is an old thread, but I Just ordered these part #'s
52300-SEP-A03 (Rear Sway)
52306-SEP-A02 (Bushings?)
52308-S3M-A00 (Holders?)
Are these the right numbers? The guy said it was for an 04-05 TL Rear Sway.
MysterGoode is offline   Reply With Quote Quick reply to this message
Old August 26th, 2005, 05:57 PM   #8
St. Louis!
Kingof3rdinput's Avatar
Thats not the 20mm. Thats for the 17mm TL. Not the TL-S. Reference the first post in this thread for the accurate numbers.
Old August 26th, 2005, 06:14 PM   #9
_
0430Steve's Avatar
while this thread is up, anyone have the link or remember the size differences between the auto and 6spd accord and tl front bar. don't remember the exact sizes. trying to remember what i have on my auto v6 and what the upgraded size difference would be on the 6spd. and tl 6spd. i know it has been listed before but i can't find the thread or info after searching.
all i want to know is what size front sway i have, what size the 6spd has, and what the 04 tl 6spd has.
if you got the info please post it, or show me the link.
thanks.
Old August 26th, 2005, 07:48 PM   #10
I believe stock Accord 6MT is 25mm. TL-S is 27.2mm.
Honcho is offline   Reply With Quote Quick reply to this message
Old August 26th, 2005, 09:05 PM   #11
_
0430Steve's Avatar
yeah, i thought the accords had 25.4 or something, and the tl was a 27. just curious about the front sway bars. already upgraded my rear to the tl 6spd bar.
Old August 26th, 2005, 09:23 PM   #12
I'm doing the front sway next week- I'll report back.
Old August 27th, 2005, 09:46 AM   #13
It will reduce body roll, which is what I'm after. If I just wanted to add oversteer to the car, you're right- the rear sway is only necessary.
Old September 12th, 2005, 12:31 PM   #14
Deepa's Avatar
WILL THIS SAME SWAY BAR WORK ON THE i4 Accord?
Old September 12th, 2005, 02:53 PM   #15
great to know, ill have to go on that site and get the rear and front done
jason2713 is offline   Reply With Quote Quick reply to this message
Old September 13th, 2005, 01:33 AM   #16
Deepa's Avatar
Old September 13th, 2005, 03:39 AM   #17
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
Some people who have swapped the rear sway have had a problem with it rubbing against an exhaust hanger (I think that's what it was hitting). Nothing major though..... some have just bent the bracket a little to alleviate the problem.
Old September 13th, 2005, 02:29 PM   #18
Deepa's Avatar
i have dual exhaust if that makes a diff, but so it does fit right
Old September 14th, 2005, 09:26 AM   #19
Rub My Belly
konatriathlon's Avatar
Send a message via AIM to konatriathlon Send a message via MSN to konatriathlon Send a message via Yahoo to konatriathlon
Yes, I have an I4 Sedan, and the TL front and rear sways fit just fine. (I actually have the Comptech 22mm TL rear sway bar though.) You do have to bend the rear exhaust hanger though. As well as the Accord Coupe V6 6 Speed upper strut bar.
konatriathlon is offline   Reply With Quote Quick reply to this message
Old September 14th, 2005, 03:37 PM   #20
Deepa's Avatar
k cool thanks guys is it better to order off net or just go to an acura dealer?
Old September 14th, 2005, 06:24 PM   #21
I bet if you print out a net price and take it to your local acura dealer, they'll match it. All of those net places (including the one I used) are just other acura dealers anyway...
Old September 15th, 2005, 08:23 AM   #22
DC Metro
Have you put this bar on yet? How much of a difference did you notice?
I have the HFP suspension on my car now with a TL 20mm rear sway, and I just recently put 225/45R17 Pirelli Pzero Nero M+S on my car. After I put the tires on I feel like there's more roll in the front.
AV6Speed Dreamz is offline   Reply With Quote Quick reply to this message
Old September 15th, 2005, 09:45 AM   #23
Big difference. Almost no front body roll plus instant steering response from the poly bushings. See my report here:
http://www.v6performance.net/forums/...t=58359&page=2
Old September 23rd, 2005, 08:48 AM   #24
mattgecko's Avatar
I just picked up an 05 M/T TL rear sway. So I need to buy (2) of each of the above parts?
(For: 05 A/T V6 coupe)
mattgecko is offline   Reply With Quote Quick reply to this message
Old September 23rd, 2005, 10:32 AM   #25
_
0430Steve's Avatar
2 brackets and 2 bushings.....the stabilizer is the actual sway bar
Old October 2nd, 2005, 02:41 PM   #26
Ok I know this has been covered but for the confused ones --me
If I am buying the polyurethane bushings from summit racing -- do I still need to purchase Part #'s
from Acura ?
Or does part #'s ENS-9-5158G replace these ..
Thanks for your help I am planning on ordering tonight
AnabolicOne is offline   Reply With Quote Quick reply to this message
Old October 2nd, 2005, 04:58 PM   #27
No, you only need to buy the bar. Energy polys replace those parts.
