Sway Bar Install - Honda Accord Forum : V6 Performance Accord Forums
Old April 4th, 2005, 09:32 AM   #1
Sway Bar Install
I purchased both the front and rear sway bars for the 2004 TL to install onto my 2004 Accord. I took it to a local Honda dealership this weekend to have it installed. They installed the rear one with no problems except for the fact that a part of what holds the muffler up is rubbing against the bar. I held off on installing the front as they told me it would require dropping the chassis of the car in order to get to the front sway. Is that correct? Also should anything be rubbing against the sway bar? TIA.
Askani is offline   Reply With Quote Quick reply to this message
Old April 5th, 2005, 10:24 AM   #2
Jinx32's Avatar
On a V6 there is no rubbing problem. I am unsure where the hanger is on an I4, but it is possible.
Correct, subframe disassembly is required for the front sway. Hence not many people to it.
J
Jinx32 is offline   Reply With Quote Quick reply to this message
Old April 5th, 2005, 10:52 AM   #3
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
Yes, the front sub-frame needs to be dropped in order to install the front bar. But I think you're going to want to get it done. There have been numerous posts about the drop-throttle oversteer problem when only the rear bar is upgraded.
And, several I-4 owners have posted about the rear sway rubbing on something back there..... maybe an exhaust hanger, I can't recall. For whatever reason, it's a problem for the 4 bangers only...... it doesn't affect us V6'ers.
Old April 5th, 2005, 11:38 AM   #4
Rolling on 19's
00&03Accords's Avatar
I have the comptech rear sway bar on my 4 banger and it doesnt rub anywhere.
00&03Accords is offline   Reply With Quote Quick reply to this message
Old April 5th, 2005, 01:23 PM   #5
Coupe or Sedan? What size bar do you have?
Old April 5th, 2005, 01:27 PM   #6
wearYELLOW :: liveSTRONG
The Sync's Avatar
It's a coupe and the bar size is 22mm for the Comptech rear sway.
Sorry 00&03Accords, I just thought I would answer his question.
Old April 5th, 2005, 01:37 PM   #7
Rolling on 19's
No problem.
Old April 5th, 2005, 03:01 PM   #8
My rear sway doesn't rub either....
Neuspeed Rear Sway!!!
hondatuner7 is offline   Reply With Quote Quick reply to this message
Old April 5th, 2005, 03:05 PM   #9
accord03's Avatar
its becuase the stock bar and the aftermarket bars are routed differently...stock goes along the bottom, where as the comptech and neuspeed go a little bit up more...but yes the i4 have a hanger near it and it rubs....get the comptech bar.
