My rims, freaken wheel OFFSET - Honda Accord Forum : V6 Performance Accord Forums
Old April 25th, 2005, 05:34 PM   #1
snipes's Avatar
Dam, after so much searching I find the perfect rims and the offset is all wrong.
If you check under specifications the 18's have an offset of 38mm.
http://www.ultrawheel.com/wheel_deta...?brand=7&id=99
Can anyone help me find rims that look like this for my black coupe?
snipes is offline   Reply With Quote Quick reply to this message
Old April 25th, 2005, 06:01 PM   #2
darkside / gen7accord.com
Blizzard's Avatar
Send a message via AIM to Blizzard
wow, bling bling =) Those look nice
Art
D a r k s i d e
Blizzard is offline   Reply With Quote Quick reply to this message
Old April 25th, 2005, 06:20 PM   #3
Whitesides's Avatar
Send a message via AIM to Whitesides
http://www.bigwheels.net/?location=w...r_vehicle=2003
slightly better, it's a +40, but that probably isn't good enough.....
Whitesides is offline   Reply With Quote Quick reply to this message
Old April 25th, 2005, 06:48 PM   #4
dme330i's Avatar
18x7.5 with 225's should work if you're not slammed.
dme330i is offline   Reply With Quote Quick reply to this message
Old April 25th, 2005, 07:10 PM   #5
indoctidiscant
OwAce's Avatar
or you can get wheel spacers that push them out 10 mm.
Old April 25th, 2005, 07:59 PM   #6
snipes's Avatar
Is it really that easy? Some one confirm please
Old April 25th, 2005, 08:30 PM   #7
nycsam786's Avatar
Send a message via AIM to nycsam786
bling bling
nycsam786 is offline   Reply With Quote Quick reply to this message
Old April 25th, 2005, 08:39 PM   #8
that would make it worse, it would make it stick out like a wheel with a 28mm offset
Old April 25th, 2005, 08:45 PM   #9
HONDA_99's Avatar
10mm space will make offset +30mm.
to get higher offset you would need to shave few millimeters of the back of rim.
to know how much you can shave you'd probably need to contact rim manufacturer.
Old April 25th, 2005, 09:08 PM   #10
Jan/Feb '06 ROTM
Dinzdale40's Avatar
Send a message via AIM to Dinzdale40
if you slam it and don't correct the camber it would be fine......lol...i mean really slam it....have to roll the fenders.....could look hot if you really want them
Dinzdale40 is offline   Reply With Quote Quick reply to this message
Old April 25th, 2005, 09:39 PM   #11
accord03's Avatar
no it will work FINE...i had 18x7.5 lowered about +2.2in with 225 tires NO rub. its a good fit and looks flush...
hard to tell on the last pic but u can see the flushness. that is with spc camber kit install in the rear....38 offset might be perfect...tho
wheel spaceers add mm....not off....which everyone already said...honda99 got it.
Old April 25th, 2005, 11:05 PM   #12
snipes's Avatar
Thanks for all the replies.
I also found out that the spacers reduce offset after reading off the net.
accord03: what is your offset on those rims and are you running 40series?
Old April 26th, 2005, 01:03 AM   #13
Deepa's Avatar
accord03 what kind of wheels are those? got any better pics?
Old April 26th, 2005, 02:02 AM   #14
accord03's Avatar
they are r-1 type 6r...got them while back for a cheap ass price....but yeha dont get them..the lug caps fell off and hit the side of my car.....i was waxing for hours.....bu tyeah....they are +40 18x7.5 with 225/40 tires.....here is two more pics...
Old April 26th, 2005, 06:41 AM   #15
indoctidiscant
OwAce's Avatar
DOH!... totally forgot it goes the otherway..i used my wheelspacers to push my wheels out a little bit..
Old April 26th, 2005, 10:39 AM   #16
snipes's Avatar
I remember you now from your old screen name.
So with 225/40/18 with an offset of +40, will not rub front or back when loaded?
If I do go with these rims, think the 235/40 will cause much difference? 235 would be perfect cause the speedo will not be affected as much.
Old April 26th, 2005, 11:06 AM   #17
I Jumped Off Da Bandwagon
Hongda's Avatar
You will rub with 235.
Old April 27th, 2005, 02:16 PM   #18
snipes's Avatar
Dam. I would never have thought 225 to 235 would be so significant.
Guess it just makes it that much wider..
Old April 27th, 2005, 05:03 PM   #19
gurdeep007's Avatar
Would this set up work, I'm dropped on HR Sports
Bolt Patter: 5x114.3mm
Offset: +38mm
225/40ZR18
I will rub right?
gurdeep007 is offline   Reply With Quote Quick reply to this message
Old April 27th, 2005, 06:39 PM   #20
k24/k20 Turbo coming soon
telele's Avatar
Send a message via AIM to telele
I'm very sure you will rub that's just to much against you.
telele is offline   Reply With Quote Quick reply to this message
Old April 28th, 2005, 07:56 AM   #21
gurdeep007's Avatar
DAMN thank though, was getting a good deal, but as usual too good to be true.
Thanks for the help!
Old April 28th, 2005, 10:21 AM   #22
telele's Avatar
No problem man it's always hard to find the perfect rim Good luck you will find a set very soon I'm sure.
