Koni Yellow ?'s - Honda Accord Forum : V6 Performance Accord Forums
Old April 26th, 2005, 03:17 PM   #1
Koni Yellow ?'s
So I just send out money in a group Buy for a set of Koni Yellow's. I want to know what dampening setting I shoudl use. I definitly would like a softer ride but wouldnt want to sacrafice handling all that much. I have Tein S tech springs and I just ordered the TL sway bar. So what dampening setting shoudl I use to get the best ride quality without sacrificing handling. As long as the handling wouldnt be worse thant what I have going on right now I woudl be ok with. Right now I just have the Tein S techs with stock shocks. Also what if any is going to be the advantage of having them on the higher perch setings?
Nsaladino is offline   Reply With Quote Quick reply to this message
Old April 28th, 2005, 12:30 PM   #2
Frisco You Know!
H&R with Koni.
2 full turns from soft to hard.
Mine is set to mid setting (1 turn) in the front
1/2 turn rear.
Make sure you LEAVE THE REAR SEAT APART until you have the proper setting. Otherwise you'll have to keep taking it apart until you find what you want. The front is much easier to get to.
zeoth is offline   Reply With Quote Quick reply to this message
Old April 28th, 2005, 02:01 PM   #3
6 Gen Accord 4cyl sedan.
Progress Sport springs, Koni Sport
Front 1.5 Turns Full Soft to Full Hard, Back 2.5 Turns Full Soft to Full Hard
Front set at 1/4 turn of full soft, Back 1/2 Turn from full soft.
From here in Quebec, Canada, where the roads are really bad, i found that anything more than my current settings was way to rough.
And i agree with zeoth, leave the back seat undone until you find the correct setting
John
ftmjohn is offline   Reply With Quote Quick reply to this message
Old April 29th, 2005, 05:36 PM   #4
sweet03accord's Avatar
H&R sports w/konis
front are set at about 1 1/4 turns from full soft
rear set about 3/4 of a turn from full soft
It boils down to your own taste and what kind of roads you drive on.
sweet03accord is offline   Reply With Quote Quick reply to this message
