RIMS Question - Honda Accord Forum : V6 Performance Accord Forums
Old May 4th, 2005, 08:46 AM   #1
Mid Atlantic Mega Meet
marshallbc's Avatar
Send a message via AIM to marshallbc
RIMS Question
Hey would a 18x8 with a 38mm off set work??? If not what do I need to look for???
marshallbc is offline   Reply With Quote Quick reply to this message
Old May 4th, 2005, 09:03 AM   #2
Yeah, that should be just fine. Your wheel should be about 2mm into your car (tucked into your body).
good luck!
lawwoo11 is offline   Reply With Quote Quick reply to this message
Old May 4th, 2005, 09:25 AM   #3
I dont think it would work. 38mm offset would make your wheels stick out alot. The stock offset is 55mm! Anything around 45mm offset would be ok!
John
ftmjohn is offline   Reply With Quote Quick reply to this message
Old May 4th, 2005, 09:36 AM   #4
John
But you have to factor in the new wheel width. Also, the stock 17"s with the +55 offset looks more into the body too. Either way, you can use the tire offset calculator shown here.
http://toy4two.home.mindspring.com/offset.html
I put in my stats, which are 18"x8.5" with a 42 offset. Mine sits flush with the body. So based on that, the 38 offset with your tire width should work just fine.
Old May 4th, 2005, 12:37 PM   #5
marshallbc's Avatar
That says my wheels would extend 30mm out further than stock... I don't think its worth the risk but thanks for saving me the time of having to send them back.
Old May 4th, 2005, 12:43 PM   #6
They'll work just fine. What the 30mm means is from your current wheel right now, you extend out 30mm. Not from where it's sitting flush because your current stock wheels do not sit flush with the body. It sits more into the body. That's what I'm trying to explain to you.
Someone will be able to confirm this.
Old May 4th, 2005, 01:06 PM   #7
Jan/Feb '06 ROTM
Dinzdale40's Avatar
Send a message via AIM to Dinzdale40
the wider the wheel is....the more positive offset you need fit...you would need at least +45-48 offset to run an 8" wide wheel......i run 7.5" wide wheels with +42 offset....and they are as flush as you can get the lip with out sctretching your fenders.....
Dinzdale40 is offline   Reply With Quote Quick reply to this message
Old May 4th, 2005, 10:39 PM   #8
yea but you have a 6th gen, people have been able to put wider wheels with lower offsets on the 7th gens
Old May 4th, 2005, 10:58 PM   #9
NO WONDER!!! You're a 6th GEN! I was like.."what the heck?!! I'm running 8.5" and a 42 offset and it sits flush.."
Old May 5th, 2005, 06:41 AM   #10
marshallbc's Avatar
I also have the tein springs you don't think I will rub or anything?
Old May 5th, 2005, 07:04 PM   #11
dme330i's Avatar
I think you will be fine. The drop, if you don't have a camber kit, will give you some negative camber which will give you a few more mm's.
dme330i is offline   Reply With Quote Quick reply to this message
Old May 5th, 2005, 07:12 PM   #12
Raddy21's Avatar
i have a question for a set of rims also, would 19x8 rims with 225/35 toyo proxes fit on our 7 gens?
Old May 5th, 2005, 07:15 PM   #13
It depends on the offset.
Old May 5th, 2005, 07:17 PM   #14
Raddy21's Avatar
sorry i forgot to add +48mm is the offset
thanks for quick response
Old May 5th, 2005, 07:26 PM   #15
It'll be fine. It won't be flush with the body of the car. Your wheels are going to retract into the body of the car by maybe 10-11mm. You won't have rubbing issues. Good luck!
Old May 5th, 2005, 07:28 PM   #16
Raddy21's Avatar
ok thats fine, thankyou very much lawwoo11!!!
Old May 8th, 2005, 11:46 AM   #17
gurdeep007's Avatar
Would the set up below work on my 7 th Gen? It's been lowered on HR sport Springs
Bolt Patter: 5x114.3mm
Offset: +38mm
with (4) 225/40ZR18 Nexen N3000 tires brand new never mounted.
I'm getting a good deal on these and need to know if they will fit.
gurdeep007 is offline   Reply With Quote Quick reply to this message
Old May 8th, 2005, 03:00 PM   #18
Sleestak's Avatar
You want to use a 235/35 tire that way your spedo wont be off as much. I have 235/35/19's on 19x7.5 wheels.
Sleestak is offline   Reply With Quote Quick reply to this message
