Problem with springs? - Honda Accord Forum : V6 Performance Accord Forums
Old May 22nd, 2005, 06:13 PM   #1
CeRtiFiEd PimP
I got neuspeed springs..i was cheking the gap on the front 2 tires.one side is different than the other...on the right side i have a 2 finger gap..on the right i cant even fit 2 fingers...is this normal or what is wrong
Old May 22nd, 2005, 08:52 PM   #2
did you install. is it springs only. you need to take off the tire on the higher side and make sure that the bottom of the strut itself is ----all the way into the bracket it sits in -------. its that "u" shaped thing that connects to the lower contol arm on the front suspension. the strut drops into this hole that is clamped by a bolt. if you installed you know what im talking about. check it out.
dt350 is offline   Reply With Quote Quick reply to this message
Old May 22nd, 2005, 09:14 PM   #3
CeRtiFiEd PimP
no clue..lol i got it done at some mechanic shop..
