Neuspeed Tie-bar - Honda Accord Forum : V6 Performance Accord Forums
Old May 24th, 2005, 10:32 PM   #1
Neuspeed Tie-bar
Have anyone installed this tie-bar on our cars?
I have problem installing it. It just could fit onto the studs.
Thank you.
tetu is offline   Reply With Quote Quick reply to this message
Old May 26th, 2005, 12:08 AM   #2
wj4
wj4's Avatar
Thank you.
i have it on the car. great mod for $100. front end feels a lot tighter when cornering.
i had the same problem..the holes were off by half an inch or so. i called neuspeed and they said it has to be forced in, if it was a perfect fit, it wouldn't serve a purpose.
so i installed one side first, then i used a rubber mallet to hammer in the other side. went in fine, and everything is a-ok now
Old May 26th, 2005, 12:15 AM   #3
I see, I thought I got the defective tie-bar. I still haven't installed it yet.
Thank you
Old May 26th, 2005, 12:30 AM   #4
Where did you guys get the tie-bar from..? Thanks.
SpiicyTuna is offline   Reply With Quote Quick reply to this message
Old May 26th, 2005, 08:01 AM   #5
wj4
wj4's Avatar
it was really random..i was bored so i was ebaying for random things. i found an auction for it with buy it now of $99.99 so i got on it. instead of paying another $15 or 20 on shipping, i asked to pick it up at neuspeed themselves, which is about a 30 miles drive from my house.
Old May 26th, 2005, 08:15 AM   #6
Your Mom Drives a Honda
smokin6speed's Avatar
now my question has always been...which is better an aftermarket one or the one that came stock on my six speed...the size appears to be the same and it appears to bolt on near the firewall as well and i haven't really found a sure answer yet....anyone?
Old May 26th, 2005, 10:04 AM   #7
I got it from ebay too
Old May 26th, 2005, 10:35 AM   #8
_
0430Steve's Avatar
i have this bar too and it was a pain to install, got frustrated for a bit thinking it was a defective bar. but after a little jimmying around i got it to work. just try it, then try the other side, maybe have a friend help.
i got my black bar off ebay for $89, great mod. feels better, i think. gave me 25 hp. if anything it looks cool.
good luck.
Old May 26th, 2005, 11:07 AM   #9
one more question, do I have to jack-up the car before I install it?
Thanks
Old May 26th, 2005, 01:10 PM   #10
_
0430Steve's Avatar
no.
Old May 26th, 2005, 07:18 PM   #11
I got it and I.. .. .."Use the Force Luke"! The Force = Rubber Mallet!
My05Sedan is offline   Reply With Quote Quick reply to this message
Old May 26th, 2005, 07:53 PM   #12
I used the mallet too, worked like a charm
Cutlr7 is offline   Reply With Quote Quick reply to this message
Old May 27th, 2005, 11:03 AM   #13
anyone have pictures of it installed?
Old May 27th, 2005, 12:36 PM   #14
_
0430Steve's Avatar
my black one.
Old May 27th, 2005, 07:18 PM   #15
From J30A to 4g63
0Tolerance's Avatar
Send a message via AIM to 0Tolerance Send a message via MSN to 0Tolerance Send a message via Yahoo to 0Tolerance Send a message via Skype™ to 0Tolerance
Silver on mine, yeah a pain for me to install too.
0Tolerance is offline   Reply With Quote Quick reply to this message
Old May 31st, 2005, 12:09 AM   #16
Send a message via ICQ to ib_604 Send a message via MSN to ib_604
i have one aswell....kinda useless on the six speed since it has a stock one...neuspeed one, more for looks....got it off ebay aswell...
the stupid thing about this bar is, that if u have koni adjustable shocks, or even the neuspeed SP3's....the adjustment knob doesnt work after the strut bar is installed, because the knob is too wide, and doesn't fit between the Y ends of the tie bar....so instead u have to use plyers...kinda gay...
Car: 04 Accord V6 6spd
Current Mods: Custom Downpipe, Comptech Rear Sway, TL Front Sway, Hyper Volt Meter and Ground Wires, VAFC2 LE, MagnaFlow Exhaust w/glass pack, Koni SP3 Shocks, H&R Sport Springs, Neuspeed Upper Tie Bar, Neuspeed Short Shifter, Grillcraft 3pc grill, K&N Typhoon Intake, PIAA Headlights & Fogs, Autopage 2-way Alarm, Passport Escort SR-1, full tint, and completely custom stereo.
ib_604 is offline   Reply With Quote Quick reply to this message
Old July 26th, 2005, 07:13 PM   #17
chino182's Avatar
how does the strut bar hold on to the chassy? screws or u just slam the hole on the lugs and then reach on the other side and do the same thing....
anyone has a close up shot inside the hole.. thanx
chino182 is offline   Reply With Quote Quick reply to this message
Old July 26th, 2005, 08:12 PM   #18
mine couldn't fit my car.
i'm sellling mine, anyone interested?
Old July 26th, 2005, 08:15 PM   #19
dont be sad it does fit. I actually got someone to make it fit for me
It would be easier if you had your car raised
TEK_03AV6 is offline   Reply With Quote Quick reply to this message
Old July 26th, 2005, 08:16 PM   #20
St. Louis!
Kingof3rdinput's Avatar
Bang that thing in there, it will fit.
Old July 26th, 2005, 09:54 PM   #21
chino182's Avatar
ill take it
Old July 26th, 2005, 09:55 PM   #22
chino182's Avatar
they are bolt on's right? you have two take off two lugs and then put over the bar and tighten back the lugs right?
Old July 26th, 2005, 10:32 PM   #23
St. Louis!
Precisely. Just take a rubber mallet to it.
Old July 26th, 2005, 11:15 PM   #24
How much would it be for the stock on that comes on the 6-speed? Would it fit for the v-6 sedan?
lukeduke1110 is offline   Reply With Quote Quick reply to this message
Old July 26th, 2005, 11:18 PM   #25
St. Louis!
Yes, the stock 6spd strut bar fits the V6 sedan.
Old July 27th, 2005, 01:22 AM   #26
Anyone know where I can get one?
Old July 27th, 2005, 04:29 AM   #27
Art M.'s Avatar
hardtopguy
Art M. is offline   Reply With Quote Quick reply to this message
Old July 27th, 2005, 07:05 AM   #28
St. Louis!
That's what he's asking for I think.
Old July 27th, 2005, 10:15 AM   #29
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
But it's also a lot more work to install. You have to remove some of the covers over the wiper linkages (at least I think that's what they are!?), and also remove the strut tower-to-firewall braces in order to install the 6-speed strut bar on the sedan. And the 6-speed bar has no advantages, imo, over the stock Honda parts already on the car once a strut tower tie bar (like the Neuspeed one) is added.
Old July 28th, 2005, 11:46 AM   #30
http://board.accordtuner.com/showthread.php?t=22974
I had problems with it too. You guys that used a mallot, how were the holes off? On mine the two holes on the same strut were too close together. I don't think a mallot could've worked for mine.
superpilun is offline   Reply With Quote Quick reply to this message
