Minimum Offset for my car - Honda Accord Forum : V6 Performance Accord Forums
Old May 29th, 2005, 11:14 PM   #1
I lower AV6 by Tein SS & SPC camber kit, please check out the pictures for my rear wheel, the top of the tire is now actually got covered by the fender with no rubbing.
and now, I am planning to get:
19" x 8
235/35/R19
What is the minimum offset I should have to avoid rubbing?
or should I go for 225/35/R19?
or even 19" x 7.5 with 225?
Thanks
triggerking is offline   Reply With Quote Quick reply to this message
Old May 30th, 2005, 01:25 AM   #2
You will rub...I suggest u Roll your fender a little bit. I have 235/35/19 and had no rubbing problems until I got my rear SPC camber kit on and adjusted. Its not that hard to roll your fender slightly. Only bad part is that some of you fender paint will chip, but can be fixed with some touch up paint. After rolling your fenders you wont rub unless you let ppl ride in your back seat or you hit a big pothole.
TEK_03AV6 is offline   Reply With Quote Quick reply to this message
Old May 30th, 2005, 04:16 PM   #3
Deepa's Avatar
instead of rolling, cut the fender its better no worries about paint chip.
Also theres a member on here forgot his name but he has 19x8 with a 40mm offset slamed on tien basics no rub.
Old May 30th, 2005, 09:29 PM   #4
Thanks for the replies, is that mean if I don't roll/cut my fender it will rub anyway even I go for 19" x 7.5 with 225/35/R19??
Old May 30th, 2005, 09:46 PM   #5
19x 7.5 shouldn't rub
but 19x8 will rub
I know for a fact b/c thats what I got. It will rub if you use your camber kit. It will not rub if your camber is all f'ed up. Thats why that one guy is probalby not rubbing b/c he doesn't have a camber kit.
Old May 30th, 2005, 09:53 PM   #6
Thanks!!
So I could use 19 x 7.5, 225/35/R19 without rubbing?
What is the minimum offset should I have?
Old May 30th, 2005, 11:58 PM   #7
Deepa's Avatar
offset for our cars is 42-45mm
heres the link to what i was talking about http://www.v6performance.net/forums/...ad.php?t=53447
search there might be more out there on this topic.
Old May 31st, 2005, 08:35 PM   #8
WildcatMike's Avatar
Check the tire "load rating".
My experience has been, the 225's below 45% sidewall are not easy to find in a load rating of "90" or above, unless you want a 15000 mile tire.
I have come accross many at 88, which from what I understand the 88 load rating tire is designed to only support 1235 pounds at MAX pressure. The autotragic comes with 91 and 6spd with 93 standard.
The gross front axel weight for the V6's is near 2400 pounds. That is too close, imo, considering the pot holes here in Houston and several hundred dollars a wheel.
Has anyone had issues with lesser load rated tires than factory?
WildcatMike is offline   Reply With Quote Quick reply to this message
Old May 31st, 2005, 10:50 PM   #9
Thanks for all your responses,
I think I am still concerning, when I get to tirerack.com and pick 19x7.5 rims,
they suggested me to use a tire 225/40/19.
Actually, to get my ODO reading correct, should I go for 225/35/19 or 225/40/19?
Old June 1st, 2005, 04:45 PM   #10
Both are less than 3% difference from stock. The OD will be more accurate with the 225/35's.
There are several tire size calculators out there.
I use http://1010tires.com/TireSizeCalculator.asp.
Old June 1st, 2005, 05:14 PM   #11
I Jumped Off Da Bandwagon
Hongda's Avatar
19X7.5 w/ 45-48mm offset and 235/35/19 tires
or
19X8 w/ 45-50mm offset and 225or235/35/19 tires
Old June 1st, 2005, 10:46 PM   #12
Hongda, are you sure 19x8 w/ 45-50mm offset and 235/35/19 tires could fit on my car? That's why I was looking for, but it seems that I have to cut / roll the fender by using this setup. Thanks
Also, thanks for your info, WildcatMike
Old June 2nd, 2005, 12:14 AM   #13
Trust me you will rub. Unless my car was made different then yours which is highly unlikely. Most people dont have camber kits installed on there car so of course they wont rub. Without your camber kit, your wheel is gonna lean inwards so no rubbing issues. But with camber kit installed and adjusted your wheel is gonna come back out so it will rub. I have 19x8 with +45 offset rims and I rub in the beginning before i rolled my fenders a little bit. You dont have to completely roll your fenders, but only a little bit where your fender is gonna stick up instead of downwards.
Old June 2nd, 2005, 02:16 PM   #14
Hongda's Avatar
Well, to be on the safe side get 48 or 50mm offset.
Old June 4th, 2005, 02:34 AM   #15
Deepa's Avatar
48 and 45 mm is not to much of a def. if you rub with 45 you'll most likely rub with 48, what i say is just get the wheels installed i mean if you rub or not its nto gonna change your mind right, so get your wheels and if you have to roll your fender its not big deal.
and go with 235/35/19 rims size 19x8.
Old June 4th, 2005, 11:40 AM   #16
Igotvtec04's Avatar
will i rub with 18X7.5 ----40 offset--- w/ 225/40/18 tires. i have a coupe lowered to the point where theres no wheel gap, and on 04 TL wheels w/ stock tires.
