Is this too much neg. camber??? HELP ASAP - Honda Accord Forum : V6 Performance Accord Forums
Old May 30th, 2005, 05:22 PM   #1
Igotvtec04's Avatar
I just had an alignment the result for the front are -0.8 L , -1.2 R, is the right side too much neg. camber???????????? Im taking my car back i dont think the tech. did it right, my steering wheel is offcenter 1150 position, if i put it to the center the car will pull to the right. Heres the result of the camber and toe Front and back after alignment. Im lowered about 2.2" F ,1.7"R
FRONT LEFT ***************************************FRONT RIGHT
Actual----Before --- --------------------------------------------Actual-------Before
-0.8 ---- -0.9 ----------------------- CAMBER --------------* -1.2 * ------1.1
0.01 -----0.22 ----------------------- TOE ----------- ----- - 0.02 -------- 0.20
REAR LEFT *************************************** REAR RIGHT
Actual------ Before------------------------------------------------Actual------Before
-1.3 ---- -1.3 -------------------------CAMBER -----------------1.5 - --- -1.5
0.07 ------ 0.19 -------------------------- TOE --------------- 0.10 ---- 0.25
Sorry i hope this doesnt look confusing, i wish i had a scanner
Old May 30th, 2005, 08:36 PM   #2
Igotvtec04's Avatar
lol 43 views and replies. I figure out myself the front left wheels needs more toe out and right wheel needs more toe in to center the steering wheel. The tech set it within factory spec., but now my car is lowered it has different specified range.
Old May 30th, 2005, 09:48 PM   #3
Yea I have mine set at positive 1.2 for the left rear and 1.3 for the right rear. The fronts you dont have to worry about so keep it at factory specs.
TEK_03AV6 is offline   Reply With Quote Quick reply to this message
Old May 31st, 2005, 04:58 AM   #4
Igotvtec04's Avatar
you mean negative???
Old June 1st, 2005, 09:45 AM   #5
Official V6P Vendor
Send a message via AIM to peteriap
I would get the rear camber closer to zero if possible. If you want to be particular, I would get both front and rear camber kits.
Peter
-Import Auto Performance
visit us at
Your source for quality performance parts!
peteriap is offline   Reply With Quote Quick reply to this message
