Trouble removing rear camber. - Honda Accord Forum : V6 Performance Accord Forums
Old June 4th, 2005, 06:35 AM   #1
I just purchased the Ingalls Rear Camber and had trouble removing the passanger side lower rear link. After removing the inner bolt/screw, the outer part of the camber is getting stuck on the bolt and won't slide off. Everything was fine on the driver side and slide right off. Has anyone else had this problem?
I'm talking bout the pix above the "Now for the lower rear link to come off ". THe bolt closest to the caliper. http://www.cardomain.com/ride/479025/7
dynasty21 is offline   Reply With Quote Quick reply to this message
Old June 5th, 2005, 01:10 AM   #2
you need a rubber mallet or plyers to pull it out. or it may be that you need to use a floor jack to raise the assembly and relieve pressure to get that bolt loose.
dt350 is offline   Reply With Quote Quick reply to this message
