Neuspeed springs and konis - Honda Accord Forum : V6 Performance Accord Forums
Old June 11th, 2005, 02:30 PM   #1
CeRtiFiEd PimP
i have neuspeed springs with a 2.25 drop in the front..if i install koni shocks will i be able to adjust it so my car is now 2.5" in the front?
Old June 11th, 2005, 04:34 PM   #2
WildcatMike's Avatar
If you get the Neuspeed Koni shocks, you can make some adjustment. The shocks made for them have 5 different spring purch placement points, each at 7mm (I believe) apart. The adjustment points should give you 0.5" max up or down.
WildcatMike is offline   Reply With Quote Quick reply to this message
Old June 11th, 2005, 04:49 PM   #3
CeRtiFiEd PimP
they only adjust .5 up or down? since my springs are 2.25" drop will it damage them if i go lower with the koni shocks. you said it can go .5" down ..so that would make is 2.75 drop..will that ruin the springs?
Old June 12th, 2005, 03:25 PM   #4
The Neuspeed Koni's that I have don't change the spring length. I can only change the support base upon which they sit.
The main concerns that I have heard so far, is bottoming out the shock itself. Using the lowest spring perch with extreme lowering springs could be an issue.
Old June 12th, 2005, 09:01 PM   #5
CeRtiFiEd PimP
oh..but its lifetime warranty on those shocks..my drop is 2.25 in the front..and i want it to be lower than that will me gettin koni shocks make it lower
Old June 13th, 2005, 01:03 AM   #6
Deepa's Avatar
do it, the shocks are made for the springs, if they bottom out put that warranty to work
Old June 13th, 2005, 08:40 PM   #7
I didn't take any pics of the shocks off the car. I was told by the local distributor/installer of Neuspeed that the middle perch installation point is closest to stock and the separation between each is 7 mm.
If that is true then using your current lowering springs with the cradle at the lowest perch point might get you a 3 inch drop.
Who knows how it will play out because of the suspension geometry???
I also understood the Koni's designed for Neuspeed will accomodate their lowering springs. I don't know if it is because of a shorter shaft or the custom perch positions or what?
I can't go that low anyway. Here in Houston, the driveways are steep for flood control and the roads are riddled with deep pot holes.
A clip snaps into the grove of your choice on the shock shell and the cradle slides over the shock rests on it. If it doesn't work out you can change the position.
O
| 7mm
| 7mm
--- <------ stock perch position
| 7mm
| 7mm
O
