raising my car - Honda Accord Forum : V6 Performance Accord Forums
Old April 1st, 2007, 09:48 AM   #1
raising my car
i have an 03 ex v6 sedan lowered on eibach prokit springs, koni yellow shocks and an ingalls camber kit on the rear axle. If I want to reinstall the stock honda springs, will I have to remove the camber kit? and if i have to remove the camber kit what replaces it back to stock?
onggiade35 is offline   Reply With Quote Quick reply to this message
Old April 1st, 2007, 09:55 AM   #2
Not sure you need to remove the camber kit, but you might want to... its kinda useless for a stock ride height car, and you might as well take it off if your chaning the springs anyways...
E
Old April 1st, 2007, 10:26 AM   #3
V6p OG
XxAznJoexX's Avatar
you can leave it there,
id recommend an alignment afterwards anyways , and the technician can adjust it for you to accomodate the stock ride
XxAznJoexX is offline   Reply With Quote Quick reply to this message
Old April 1st, 2007, 10:30 AM   #4
I ♥ my Honda
VTEC4Lifee's Avatar
Send a message via AIM to VTEC4Lifee
Is this your car with a pro-kit drop(1.5 inches)?
VTEC4Lifee is offline   Reply With Quote Quick reply to this message
Old April 1st, 2007, 06:08 PM   #5
no. i think that was when i had the sportlines on. i switched to the prokits when the tires kept woring out on me.
Old April 1st, 2007, 06:10 PM   #6
so basically i can leave on the camber kit/koni yellow shocks and just change the prokits back to the stock honda springs?
Old April 1st, 2007, 06:45 PM   #7
yes u can leave the camber kit and koni yellows on the car and change back to prokits. from what i have heard even people with the prokits still needed a camber kit for the rear of the accord.
just switch the springs, get an alignment and you should be good to go.
villaen is offline   Reply With Quote Quick reply to this message
