Offset for 20" - Honda Accord Forum : V6 Performance Accord Forums
Old April 5th, 2007, 09:31 AM   #1
datboiroy's Avatar
Send a message via AIM to datboiroy
Offset for 20"
hey guys, my friend has a 7th gen and is planning on getting 20x8 wheels and was wondering what offset he should get, the wheels are custom so what would be the best offset for the wheel?
edit 8/5/07: hey guys what do you think of 20x8.5 with a 40 offset? and ill use 225/35/20 tires. suspension is tein ssp slammed.
datboiroy is offline   Reply With Quote Quick reply to this message
Old April 5th, 2007, 09:39 AM   #2
40 offset....this is how mine look with 1.5" drop...flush
jason2713 is offline   Reply With Quote Quick reply to this message
Old April 5th, 2007, 09:47 AM   #3
oSCaR
v6_ccord_2k5's Avatar
et40
Old April 5th, 2007, 09:49 AM   #4
DaRegulator's Avatar
Depends what you want really... I have 40 offset as well and it sits very flush... the problem is that Im dropped as well... when I had it to a one finger gap, it rubbed on my tires and it started peeling the tires a bit... so I raised it up to 2 1/2 fingers and now I dont have that problem, but its not as low... I still would go 40 cuz it looks the best ...
DaRegulator is offline   Reply With Quote Quick reply to this message
Old April 5th, 2007, 02:07 PM   #5
datboiroy's Avatar
what if your going for 0 finger gap or -1 finger gap (barely tucking)
Old April 5th, 2007, 02:35 PM   #6
oSCaR
for that I would use a 225 tire. and to back it up I would look at sick6speeds (aka drews) accord:
he had 20x8.5 Maido GR5's with et44 (Im sure you know what car Im talking about)
he was running 225 tires and he was slammed to the floor with no rubbing issues.
a 20x8 et40 will sit at virtually the exact same location (2mm short) and the 225 tires will ensure no rubbing. that is if you run the exact same camber as drew.
or if you really want the 235 for wheel protection then run camber or tuck the wheel mag in about 3-4mm... which will void the flush look.
Old April 5th, 2007, 02:56 PM   #7
datboiroy's Avatar
ya i kno who's car you talking about, where can i find his pics? i cant seem to find it, i only found a rolling shot, i member he had a pic of the wheel and there was a side shots.
Old April 6th, 2007, 12:14 AM   #8
accord03's Avatar
if ure gonna go tucked...be safe and get +45...that way u can run a 235/30/20 tire or so. +40 with 235 might be to cutting it close if dont roll the rear fenders.
RIP
Hello Prius.
old sn: AwSoMNaMjA
Old April 6th, 2007, 12:53 AM   #9
03ondubs's Avatar
225 35 definately doesn't rub, my drop is only htechs though & my offsets 38 or 40 i forgot
when I had 245 35 20 it rubbed in the back and front
03ondubs is offline   Reply With Quote Quick reply to this message
Old April 6th, 2007, 11:31 AM   #10
datboiroy's Avatar
so 45 offset with 225 tires?
Old April 6th, 2007, 02:35 PM   #11
03ondubs's Avatar
that sounds good to me, u should be able to drop as low as u want with that size
Old April 6th, 2007, 03:57 PM   #12
datboiroy's Avatar
alright ill tell my friend and get pics whenever he does it. thanks
Old April 6th, 2007, 04:35 PM   #13
accord03's Avatar
235 tires would be best...if u go 225 u can go to a +40 offset...but i would opt to get the 235 to stay within stock ratio.
RIP
Hello Prius.
old sn: AwSoMNaMjA
Old April 7th, 2007, 08:31 AM   #14
datboiroy's Avatar
my friend said he wants to go 8.5 wide with a 44 offset after seeing drew's car
Old April 12th, 2007, 12:50 PM   #15
GODDDDD DAMMMMMNNNN!!!!
i need suspension specs on that car picture above.....STAT!
Mr. Vapor is offline   Reply With Quote Quick reply to this message
Old April 12th, 2007, 01:19 PM   #16
datboiroy's Avatar
slammed on tein ss-p, thats all i know
Old April 12th, 2007, 06:49 PM   #17
customaudioman's Avatar
you can do 245-35-20 tires w/20x 8.5 wheels w/ an 45offset.
I have the same setup on my accord. here are some pics at
www.cardomain.com. serach for customaudioman
customaudioman is offline   Reply With Quote Quick reply to this message
Old April 14th, 2007, 10:30 AM   #18
datboiroy's Avatar
i dont think id be able to slam the right with those tires, i see if i drop it, it'll rub on the fender.
Old April 14th, 2007, 01:54 PM   #19
oSCaR
Drew was running rubber bands on his wheels (very stretched tires) so thats why he was able to clear his fenders no problem. Same thing that Roy (accord03) had to do with the Modenas he had.
for 8.0" wide?
no... 45 offset with 235
40 offset with 225 (Id recommend against going this route tho)
drop it any and it'll rub all four corners.
Old April 14th, 2007, 02:19 PM   #20
neeeeeeeeeeeeeeeeeeeeeeel
implayaz9's Avatar
specs on drew wheels/tires?
Old April 14th, 2007, 03:32 PM   #21
datboiroy's Avatar
its going to be 20x8.5 with a 44 offset slammed on tein ssp just like drew
drew is 20x8.5 with 44 offset on tein ssp and his tires are 225/35/20
Old April 14th, 2007, 03:50 PM   #22
oSCaR
I hope the wheels are quality wheels like Drews Maido GR5's or else you'll dent them in no time with the 225 tires.
Old April 14th, 2007, 04:58 PM   #23
datboiroy's Avatar
the wheels my friend have chosen run close to a grand each, so im pretty sure they are good quality. im thinkin about axis wheels, are those good quality? or easy to bend?
Old April 14th, 2007, 07:18 PM   #24
somethingJDM.com
duRritztiNy's Avatar
man. after looking at drews car im going lower.
duRritztiNy is offline   Reply With Quote Quick reply to this message
Old April 15th, 2007, 04:44 PM   #25
datboiroy's Avatar
can you go lower? i thought u couldnt anymore?
Old April 15th, 2007, 08:53 PM   #26
Formerly EPS Sniper
ATX 6Speed's Avatar
Send a message via AIM to ATX 6Speed
I'm curious to see your friend's car. Sounds like it'll be hot with the 20s.
ATX 6Speed is offline   Reply With Quote Quick reply to this message
Old April 15th, 2007, 10:20 PM   #27
somethingJDM.com
i can go lower. Maybe if i get off my lazy ass then I would do it.
Old April 21st, 2007, 11:04 AM   #28
datboiroy's Avatar
is 235/30/20 similar to 225/35/20?
Old April 21st, 2007, 12:03 PM   #29
V6p OG
XxAznJoexX's Avatar
on is wider, and one has a larger profile lol
XxAznJoexX is offline   Reply With Quote Quick reply to this message
Old April 21st, 2007, 05:21 PM   #30
datboiroy's Avatar
ya but i thought if its 225/35 then it would stretch right? and if its 235/30 it wouldnt stretch as much as the 225 right? i think im confusing myself.
