Help please on tire size - Honda Accord Forum : V6 Performance Accord Forums
Old April 28th, 2007, 08:40 PM   #1
vtec_babe05's Avatar
Send a message via Yahoo to vtec_babe05
I have the HFP suspension and just purchased a set of wheels that are 18x8 +35 offset. Can someone please give me some advice on what size tires I should run with this set up? Thanks ya'll!
vtec_babe05 is offline   Reply With Quote Quick reply to this message
Old April 28th, 2007, 08:45 PM   #2
I OWE benf656 MONEY
shon.nv's Avatar
on the 18x8 you should get 235/40/18 or 225/45/18. With the 35mm offset, Iam think you will have rubbing issues but not sure about it.
Old April 28th, 2007, 09:00 PM   #3
Thanks very much! OK dumb question, but what is the difference between the 225-45 and 235-40, is one thicker or wider than the other ? And you think the tire may rub the fender well? I still have some wheel gap so maybe it will be ok.
Old April 28th, 2007, 09:55 PM   #4
I feel da need 4 6-speeds
flyvtec's Avatar
http://www.rims-n-tires.com/info_specs.jsp
Click on the link. With 235/40/18 on 18x8 w/35 offset ... it reads that this set up will be 1.2" wider that stock, so my interpretation is that it will rub if you are lowered.
Old April 29th, 2007, 12:09 AM   #5
I OWE benf656 MONEY
shon.nv's Avatar
Yes the 225/45 is thicker and the 235/40 will be wider. I'd go with the thicker i.e. 225/45 because it gives better ride quality plus with the 35mm offset, it wont rub.
225/45 FTW for you
Old April 29th, 2007, 03:33 AM   #6
Jackthewack's Avatar
225 40 is what i use they seem pretty good, but my rears would rub if they were any bigger. with a 18" x 8" 42+offset
Jackthewack is offline   Reply With Quote Quick reply to this message
Old April 30th, 2007, 08:38 PM   #7
Ok well I am def not going to put the 35 offset on my car, I think it wll look bad sticking out, so I'm trying to get the seller to swap them for 40 offset.....oh gawd I hope they havent sent them yet!
