New suspension installed - Honda Accord Forum : V6 Performance Accord Forums
Old June 6th, 2007, 08:10 PM   #1
Knale's Avatar
Send a message via AIM to Knale
When I first bought my car, I had no intention of doing any mods. I was basically happy with the car. But... Those damn gaps kept on looking worse as I compared them to other cars. So I broke down and got the Eibach Pro Kits and Koni Sports installed. Springs are on the middle perch. Didn't want anything too drastic. Just got it back today. Looks really nice, but I will wait a bit to let everything settle before I take pics. Give it a week or 2
Knale is offline   Reply With Quote Quick reply to this message
Old June 6th, 2007, 09:26 PM   #2
CeRtiFiEd PimP
Old June 7th, 2007, 04:08 PM   #3
Shouldn't take that long to settle.... Should only take a few days depending on how much you drive....
The Coupe J.R. is offline   Reply With Quote Quick reply to this message
Old June 7th, 2007, 08:16 PM   #4
Knale's Avatar
I'll go ahead and post. Not sure how much a suspension will settle. Looks good to me now. I have to be carefull over speed bumps because of the front mud guards. Ride is different from stock, but not alot. Firm but still smooth. Anyway here are a few quick shots.
Old June 7th, 2007, 08:49 PM   #5
That looks good!! I need to raise my basics back up to that height... Lower = more problems in my book...
Old June 7th, 2007, 09:52 PM   #6
-Brian
NexsoN's Avatar
hey man, that looks great. we got all these guys going crazy over these coilovers and spending alot of money, but I mean konis paired up with a decent spring is a great option
Old June 7th, 2007, 10:59 PM   #7
I feel da need 4 6-speeds
flyvtec's Avatar
That looks great man! So who did the install? Are you going to tint your windows?
Old June 8th, 2007, 12:54 AM   #8
you gotta rub to dub!
relentless's Avatar
With that drop are you planning on getting 18's or bigger wheels?
Dont worry about the mud guards! Those things are indestructable!! Mine scrape every driveway and they still look good......except for the bottom part that scrapes.
Old June 8th, 2007, 05:03 PM   #9
Knale's Avatar
Thanks... How it sits is my personal taste... But I do agree that lower you go, the more of a PITA it is to get around.
Old June 8th, 2007, 05:05 PM   #10
Knale's Avatar
Thanks ... I did quite a bit of reading and asking around. This fit what I was looking for and I heard mostly positive things about this combination. The main complaints was it wasn't enough drop. But I just figure thats all in ones personal taste.
Old June 8th, 2007, 05:14 PM   #11
Knale's Avatar
Thanks flytec. I went with AJ-USA for the install. They were a bit more, but the service is awesome. While they had my wheels off, they detailed them inside and out, also washed the car inside and out afterwards. They are a place the specialize in performance upgrades for higher end cars than the Accord. He said that they had done quite a few of the 7th gen coupes. So it was more of a piece of mind thing with me. I'm kinda picky that way Anyway, everything was perfect. I'm extremely happy. I have had tint on other cars. I decided to not to do these. I like to be different
Old June 8th, 2007, 05:18 PM   #12
Knale's Avatar
That could be in the future. I would not do that until I wear out the factory tires. Since I probably only average seven thousand miles a year( I commute on a bicycle to work), that may be awhile.
I'm getting better at speed bumps, so the mud guards are safe .
Old June 10th, 2007, 05:40 PM   #13
Looks great. Nice even drop. Should have come that way from the factory.
oldmansi is offline   Reply With Quote Quick reply to this message
Old June 10th, 2007, 08:18 PM   #14
Knale's Avatar
Thanks man. I agree that it should of looked this way from the factory.
Old June 18th, 2007, 03:11 PM   #15
J35 6Spd
that looks awesome! i just bought the same setup as you and will be installing it this weekend. anyone have any advice for installing the shocks and springs? never done it before but i have a friend helping who has installed them on his maxima.
Old June 18th, 2007, 03:18 PM   #16
Formerly EPS Sniper
ATX 6Speed's Avatar
Send a message via AIM to ATX 6Speed
Take your time with it and it shouldn't be a problem at all. For the rear, I recommend loosening the top bolts while the car is on the ground, then lift it up and do the rest of the install. When installing the new rears, bolt in the bottom part and loosely install the top bolts, then lower the car and tighten the top with the suspension under full load. Here's the instructions from Honda:
http://www.handa-accessories.com/accord/hfpsusp.pdf
ATX 6Speed is offline   Reply With Quote Quick reply to this message
Old June 18th, 2007, 03:31 PM   #17
J35 6Spd
btw did you need a camber kit on the car?
Old June 18th, 2007, 03:35 PM   #18
J35 6Spd
eps thanks for the instructions i'm going to study up on these while theyre on the way
Old June 21st, 2007, 09:11 PM   #19
Knale's Avatar
Sorry... been in Oklahoma for a week. But anyway...thanks for the comment. This setup does not need a camber kit on the middle perch. If you go to the bottom perch you could need one.
Old June 22nd, 2007, 12:02 AM   #20
i'm thinking of doing the same setup eibach springs/koni yellow shocks could u tell me the price for the setup beside the instal i'm gona do it my self and can u recomend a good place to buy them plz
ivan is offline   Reply With Quote Quick reply to this message
Old June 22nd, 2007, 10:13 AM   #21
even though this question is directed to me. the only place that i know who sells the koni yellows and eibach pro-kit springs together is shox.com. but the thing with them, they are selling it for like $745.00.
i would like to go with the same setup with my car but since neuspeed has the supercup kit, for which you can switch the race springs for the sport springs (contacted neuspeed about this since on their website they said no substitutions), for $599 including free shipping, that seems like a better deal for which i am planning on getting.
still searching to see if i can find a koni yellow and eibach pro-kit setup for less online compared to shox.com.
villaen is offline   Reply With Quote Quick reply to this message
Old June 22nd, 2007, 12:00 PM   #22
hella flush
lilfotoman's Avatar
looks pretty good with the drop.
Old June 22nd, 2007, 12:36 PM   #23
Knale's Avatar
I paid 760.00 with free shipping from AJ-USA.
Old June 22nd, 2007, 01:13 PM   #24
relentless's Avatar
I had no idea AJ USA was a shop for autoparts! I drive by it every day and its only 1 minute from my house!
Old June 22nd, 2007, 01:21 PM   #25
LaLaLaLa
stupidaznmunkey's Avatar
drop looks good
where in socal are you???
Old June 22nd, 2007, 03:05 PM   #26
Knale's Avatar
Originally Posted by stupidaznmunkey
drop looks good
San Diego area
Old June 22nd, 2007, 03:11 PM   #27
Knale's Avatar
I'm not really sure of how much stock they carry there though. I ordered it through them, but it actually came from Koni and Eibach to my house. AJ-USA is also a service garage. They specialize in Porche, BMW, Mercedes,...etc. They do collision repair also. And to top it off, they sell a few high end used cars also.
Old June 24th, 2007, 12:52 AM   #28
tanx a lot that halped i'm gona order them next week for aj usa seems ok price and i'm geting my tl-s 20mm rear and 27.2 front installed allredy orderd them today i thing it gona go prety good wt koni/eibach on a 07 4dr v6
Old June 24th, 2007, 01:05 AM   #29
Your V6P Snake Champion
oswhiteboy's Avatar
looks good.. Remove mud flaps ftw
oswhiteboy is offline   Reply With Quote Quick reply to this message
Old June 24th, 2007, 01:06 AM   #30
dc dport
i have a q thats a little of topic i'm trying to build full sespintion setup and i found the dc sport carbon-steel strut bar on aj usa but i was wondering i have a 4dr 07 v6 AT and on there site there is only for 03-05 can some one halp me out i wana know if it will fit my car with no problems i thing the chasy is the same on 05 4dr and 07 but i might be wrong don't whant to order than find out that it doesn't fit thanx
