Tein S.tech + Koni Yellow = Best Combination ? - Honda Accord Forum : V6 Performance Accord Forums
Old August 13th, 2007, 02:26 AM   #1
BLK HWAK
minhokim86's Avatar
Hi guys!
i am currently running with TL rims with 235/45/R17 tires + Tein S.Tech springs + stock shocks..
it's been more than a yr so far, and
just got into a good chance that i can get Koni Yellow shocks for real cheap,
and..was wondering if this is a good set up or not,
and..if i set the koni up @Lowest peak,
is it gonna be ok with rubbing issue?
pics might also help me out !
thx in advance. !
&mpt=[CACHEBUSTER]">
minhokim86 is offline   Reply With Quote Quick reply to this message
Old August 13th, 2007, 06:49 AM   #2
hella flush
lilfotoman's Avatar
youll be fine. i was going to go that route too. i had teins s tech with the TL rims, and then i was gonna pick up some koni yellow's but instead got some ksports. itll be a good setup s techs+konis.
Old August 14th, 2007, 07:00 PM   #3
BLK HWAK
minhokim86's Avatar
did u have same tires?
bcuz of offset, it kinda looks like if i do lower more, it will rub the fender...
Old August 14th, 2007, 07:18 PM   #4
hella flush
lilfotoman's Avatar
yeah i did, 235/45/17 with a +45 offset right?
Old August 14th, 2007, 07:20 PM   #5
DV8
Hella Functional
DV8's Avatar
that's an expensive set up. For a 100-150 more, u can probably grab a set of coilovers
Old August 14th, 2007, 07:21 PM   #6
hella flush
lilfotoman's Avatar
i agree. thats what i did
Old August 14th, 2007, 07:23 PM   #7
eat'em up
TYRONE's Avatar
Originally Posted by minhokim86 View Post
Hi guys!
thx in advance. !
this is the exact set up i have, the only difference is i have 19's. i have no rubbing issues, except when i ride two people in the back(which hardly happens)
TYRONE is offline   Reply With Quote Quick reply to this message
Old August 14th, 2007, 07:37 PM   #8
Jerzy
killahsi2003's Avatar
Hi guys!
thx in advance. !
quick thin how dose the stock shocks feel after the springs do they bottom out or did they blew?
killahsi2003 is offline   Reply With Quote Quick reply to this message
Old August 17th, 2007, 11:47 AM   #9
BLK HWAK
minhokim86's Avatar
thx for the reply guys !
i know...but i got a chance to get one for around $200 only...so..
stock shocks didn't blew yet , (it's been more than 2yrs so far..)
riding feels...pretty comfort...not that stiff...
Old August 17th, 2007, 11:49 AM   #10
BLK HWAK
minhokim86's Avatar
yes
Old August 18th, 2007, 12:53 PM   #11
I OWE benf656 MONEY
shon.nv's Avatar
I've had Koni yellows with S-techs and H-techs, it was pretty good but the putting it together and adjusting the height is a ***** plus the ride quality was a bit harsh. I'd strongly recommend that you get TEIN SS coilovers, it will cost you the same but you will get more levels or dampening adjustment, easy to adjust the height and stock like ride quality with good handling.
Koni's on the lowest perch with S-tech wont give you rubbing issues but your car will be SLAMMED to the ground. You wont be able to reverse park like in the picture cause your exhaust will touch the curb and you will have to go extra extra slow on bumps ans stuff.
Old August 20th, 2007, 09:53 AM   #12
BLK HWAK
minhokim86's Avatar
Thanks shon !
hmm...ride quality for now, just with TeinS seems ok, but..i will have to see after installing Koni...
unless it's toooo stiff, i think i have to bare
i wante to go with Tein SS, but i got a new Koni for really cheap (around $200 US..) so i couldn't resist the temptation ;;;
maybe i will dig in new Tein SS later on...
Yes, i will set it up @ lowest perch, and want that Slammed look.
things concerned abt are parking fr/bk , bumps etc...
thx for the info !
*PS: do you have any pics on your car for a sample?
Old September 17th, 2007, 12:02 AM   #13
BLK HWAK
minhokim86's Avatar
Exclamation AFTER DROPPED with TeinS+Koni Yellow
Finally got a chnace to install Koni Yellow Shocks and... here are pics ! (for anyone who's thinkin abt same set up..)
2005 Accord V6
*PS: is this proper drop with TeinS+Koni's ?
(it's on Lowest Perch...and i don't see that much of diff. from the time when i used to run with TeinS+Stock shocks except front wheel gap..)
people say if i get the HFP Kit, it will look even lower..but i dunno if it will make that much of difference though..
I want to SLAM my car more, and i am thinking abt either getting Tanabe/Neuspeed springs or TeinSS-p...
Driver's Front
DR
Passenger's Front
PR
Overall
Old September 17th, 2007, 02:09 AM   #14
4th and 7th gens
Did you need a camber kit or are your wheels still within specs
black6speed is offline   Reply With Quote Quick reply to this message
Old September 18th, 2007, 10:06 PM   #15
how much lower did your car drop after u changed from stock shocks to the konis??
tofe is offline   Reply With Quote Quick reply to this message
Old September 18th, 2007, 10:48 PM   #16
StreetRacer4Eva's Avatar
Damn that looks perfect...i wish i could go this low...the garage at my job just won't allow it..lol.
StreetRacer4Eva is offline   Reply With Quote Quick reply to this message
Old September 19th, 2007, 02:21 AM   #17
BLK HWAK
minhokim86's Avatar
i didn't install any camber kits, yet.
i can see tires are done from inner side for sure, but camber is not that crazy Yet...
Front: had 2/half~3 fingergaps only with Tein S ,
Now...no gaps...
Rear: had 1/half~2/half gaps,
now, no gaps....
maybe i need another spring lower than Tein S , like...Neuspeed
which will make my car more get slammed,
or go for Tein SSP...
it kinda make sense that if i do have lower spring than Tein S with Stock shocks, after installing Koni's should make my car more slammed even more than now...
also..once i get HFP kit, it will LOOK lower...bcuz, there's gonna be something more under the bumper...
thank you !
yes..i do scratch everytime i get in/out of my garage...lol
Old October 31st, 2007, 07:12 PM   #18
Wow thats such a nice look, one day i tell you one day my car will be lowered lol very nice man get that front lip
aDo Manija is offline   Reply With Quote Quick reply to this message
Old October 31st, 2007, 09:38 PM   #19
M
imnotmatt1189's Avatar
what perch are the konis on?
imnotmatt1189 is offline   Reply With Quote Quick reply to this message
Old October 31st, 2007, 10:10 PM   #20
BLK HWAK
minhokim86's Avatar
thx for the comment ! i am trying to get the lip kit...and 06+ trunk....lol
it's on the lowest....but i wanna slam it more though...
Old October 31st, 2007, 10:23 PM   #21
M
if you want to go just a tiny bit lower you should go with the neuspeed race springs. i have them and im on the second to lowest perch and im just as low as you are.
Old October 31st, 2007, 11:26 PM   #22
DaLab
LyRiKaL_CM8's Avatar
ur car looks perfect man, it's a nice drop to me. i'd keep it like that
i have tein basics and i had my car slammed for about 2 months, no gap...u could only see a little of the top profile of my tires and to me it's not worth it. camber was crazy, got that fixed, clearance issues, i used to scrub quite a bit but that's aight....i just raised it up to about where u are and i'm satisfied now
but that's just my opinion....but don't get it twisted, i love that slammed look. when i hit another car show, i'll proly slam it again lol!
this was how i had it:
u should go with tein ss
LyRiKaL_CM8 is offline   Reply With Quote Quick reply to this message
Old March 29th, 2009, 11:24 AM   #23
Melissa
looks great
meli8197 is offline   Reply With Quote Quick reply to this message
Old March 29th, 2009, 10:32 PM   #24
i did the S-tech and koni set up.... not enough fine tuning, i replaced the springs with ground control coil overs and love them, i have run D2 and h&r coil overs on other cars and i was just as happy.
kilo6_one is offline   Reply With Quote Quick reply to this message
Old March 30th, 2009, 06:40 AM   #25
Crimson Tide
Blackhawk's Avatar
Send a message via AIM to Blackhawk Send a message via Yahoo to Blackhawk
Very nice setup Min, I like the drop. It's not too high, not too low, and tasty
Blackhawk is offline   Reply With Quote Quick reply to this message
Old April 16th, 2009, 12:07 AM   #26
Looks nice, I want mine slammed but its not practical where i am on Long Island. You drop is great
beljamstriker is offline   Reply With Quote Quick reply to this message
Old May 10th, 2009, 11:02 PM   #27
Question -- I've got koni yellows and tein s-techs sitting in a box... paid 300.00 for the set (no complaints here!) -- I don't really want to slam my car -- just get the front and rear level, using the stock wheels -- think, 1-2 finger gaps... What perch should I use?
Thanks!
theskunk is offline   Reply With Quote Quick reply to this message
Old December 3rd, 2009, 11:23 AM   #28
M![email protected] \_(ツ)_/
HEcreated487's Avatar
THREAD REVIVAL
Ride looks great Min !
Just had some questions when you were on the stock shocks: How many miles were on your stock shocks when you first installed the S.Techs? How many miles did you use the S.Techs with the stock shocks? No issues (leaking, blown)? Thx!!
Old December 9th, 2009, 03:53 PM   #29
koni has always been a favor in the integra/civic/ community, also would note that many of the tl guys like it as well. Im also a fan
hatchconversion is offline   Reply With Quote Quick reply to this message
Old December 18th, 2009, 08:53 AM   #30
Honda Nation OGON
Accordn2Blk's Avatar
Send a message via AIM to Accordn2Blk
So how is the ride now on the Koni yellow with Tein S springs... is it hard or soft?
Accordn2Blk is offline   Reply With Quote Quick reply to this message
