15" steelies on 6MT Coupe? - Honda Accord Forum : V6 Performance Accord Forums
Old September 19th, 2007, 07:58 PM   #1
rajin929's Avatar
Would there any issues on running a 15" wheel on a 6MT Coupe? or would 16" be the smallest I can go?
I'm looking for a set of used wheels for my car so I can throw some winter tires on them. 16" OEM Honda wheels in nice condition are hard to come by - the guys with prelude blades, or accord/rsx/8th gen civic wheels are asking a fortune
I see a ton of 15" wheels, both OEM alloy and steelies for sale in my area where I live, and I could run a 205-65-15 winter tire setup for much less $$
can I run the 15" with no problems?
rajin929 is offline   Reply With Quote Quick reply to this message
Old September 19th, 2007, 08:04 PM   #2
Doc
J35S004
Doc's Avatar
You may have to run 17s due
to brake caliper issues.
Doc is offline   Reply With Quote Quick reply to this message
Old September 19th, 2007, 08:10 PM   #3
rajin929's Avatar
snap, didn't know the brakes on the 6mt were larger (or different) from the other v6 accords.....I gotta do some more research lol
Old September 19th, 2007, 08:16 PM   #4
StreetRacer4Eva's Avatar
ah hah...Doc i've been thinking of a similar set up but not for the winter, rather a drag tire set up. I would also like to know whats the smallest we can go as far as steeies go. If not, i will probably have to pick up some lightweight rims for the front and mount some drag radials on them. We'll see...
StreetRacer4Eva is offline   Reply With Quote Quick reply to this message
Old September 19th, 2007, 08:35 PM   #5
Send a message via ICQ to Jackspeed
15" Steelies are a no go on the 6MT, you have to go with 16's unfortunately. You should be able to pick up some new 16" rims relatively cheap $50-$65 a piece. But i would make sure that they are hub centric or at the very least (not sure if you even can with steelies but) get hub centric rings. This will avoid many potential vibration issues.
Jackspeed is offline   Reply With Quote Quick reply to this message
Old September 19th, 2007, 10:37 PM   #6
08 Altima Hybrid....
6spNaviRacer's Avatar
I have some 16 x 8 rims from a nsx that fit up front.
6spNaviRacer is offline   Reply With Quote Quick reply to this message
Old September 19th, 2007, 11:06 PM   #7
Doc
J35S004
Doc's Avatar
Pics please...
Old September 19th, 2007, 11:16 PM   #8
Accord_V6_400m's Avatar
Pics please...
Yeah its a pretty cool setup I thought about it before too. 16's is a low as you can go, and even then you'll probably need a 5mm spacer.
Old September 19th, 2007, 11:19 PM   #9
Pics please...
Ditto..thats nice and wide. Maybe those would be a good option.
Old September 19th, 2007, 11:22 PM   #10
Doc
J35S004
Doc's Avatar
Where in the heck is La Quinta, CA?
No I'm curious.
Old September 20th, 2007, 08:07 AM   #11
No I'm curious.
A better phrase is to say " where in hell is La Quinta "
It's in the desert just past Palm Springs and on the hottest day it can get 120 degrees.
Siggy took a pic months ago at the drags.
I don't have them on the car right now I'm trying my lightweight
kosei k1 17x7.5 with nitto 245 wide DR's.
AS far as the 16x8 nsx rims a spacer is needed because the tires rub on the inside, but the rims clear.
Old September 20th, 2007, 08:16 AM   #12
Doc
J35S004
Doc's Avatar
Just past Palm Springs going east? 120 degrees? That sounds like it would really suck.
Someone is going to machine spacers for you for the NSX rims??
Old September 20th, 2007, 09:38 AM   #13
You don't need spacers for the Kosei's right? Where did you pick them up from?
Old September 20th, 2007, 10:03 AM   #14
I no Nintendo
gizmo2003's Avatar
I trying the hole 15" wheels, it would of worked if I had extended lugs just put it this way it was a hole lot of spacers...I was trying to put some slicks on.
Old September 20th, 2007, 12:29 PM   #15
rajin929's Avatar
16" it is then, I'll continue to keep my eye out for a cheap set.
Hubcentric FTW
Old September 20th, 2007, 05:34 PM   #16
I have been using standard 5/16 spacers from the autoparts store.
The kosei's have a +45 offset so no spacer needed and they came from tire rack.
Old September 20th, 2007, 09:30 PM   #17
Hubcentric FTW
Did you mean WTF?
This link should explain it pretty well.
http://www.miata.net/garage/hubcentric.html
Hope that helps
Old September 20th, 2007, 10:03 PM   #18
I can't find K1's in 7.5" on Tire rack. Only 7" and 8". I'm looking for the K1 Racing one's but they seem not to be available for our car. At least they don't show up.
Old September 20th, 2007, 11:45 PM   #19
Did you mean WTF?
Hope that helps
a smiley face next to WTF
FTW= For the Win apparently he likes it to be hubcentric, I don't blame him
Old September 21st, 2007, 05:08 AM   #20
ahhh sorry, my bad
Old September 21st, 2007, 08:13 AM   #21
It's been almost 2 years, I think you will have to call them direct and ask for k1 racing. You only find newer styles on the web site.
Old September 24th, 2007, 11:32 PM   #22
badaz6spd
so the 15" will fit with a 5/16 spacer on the 6 speed?
darla is offline   Reply With Quote Quick reply to this message
Old September 25th, 2007, 08:25 AM   #23
NO! 15 inch will not work.
the 5/16 spacer is for the 16 x 8 nsx rim.
Old September 25th, 2007, 03:28 PM   #24
rajin929's Avatar
hahaha, YES!
Old October 3rd, 2007, 10:14 AM   #25
rajin929's Avatar
so I ended up picking up a set of 16" steelies off a local guy who had a TSX. That'll work for now, since I'll be throwing snow tires on em' don't need to be all fancy with OEM alloys that'll probably be wrecked with the salt....
Old December 30th, 2009, 09:22 AM   #26
So the 16" steel wheels fit on the v6 6spd coupe?
Old December 30th, 2009, 02:15 PM   #27
rajin929's Avatar
whoa - talk about bringing up an old thread!
can't knock you though - better you search and reply, then start a new thread and get flamed lol
yes, 16" steel wheels will work on the 6spd coupe. This is my 2nd winter using the set I bought back in 2007 (didn't use winters 07-08, took the chance and wore down my all seasons before putting these 16's on 08-09)
2005 Honda Accord EX 6MT Coupe - Graphite Grey Pearl
