Help!!!! Car Swaying side to side!! - Honda Accord Forum : V6 Performance Accord Forums
Old October 3rd, 2007, 12:38 AM   #1
Adventure is out there!
littletruong's Avatar
Exclamation Help!!!! Car Swaying side to side!!
Okay i finally got around to adjusting my ingalls rear camber kit today.. When i finished adjusting it.. i took my car out for test drive, and noticed that my car swayed side to side a lot more than before..I took it on the highway, and everytime i switched lanes it felt as if the back of my car wanted to spin out. Even while i was driving straight on a road, the car would sway back and forth if i hit bumps and depending on the condition of the road. I have the comptech rear sway bar, but i didn't touch that. For some reason it just feels like the car is swaying. Is there a certain degree you're supposed to adjust the camber and toe?? Please if anyone has any information regarding this, would be greatly appreciated.
oh yea, i'm slammed on tein ssp also if anyone is wondering what suspension i'm on.
Old October 3rd, 2007, 12:46 AM   #2
Bobby Lane Racing
nighthawk04v6's Avatar
take it to a professional allignment shop bud. so they can adjust your camber properly
Old October 3rd, 2007, 12:47 AM   #3
Senior Member
nicepeta's Avatar
you should do the alignment...
the machine will correct it for you.
nicepeta is offline   Reply With Quote Quick reply to this message
Old October 3rd, 2007, 12:49 AM   #4
^^so should i just take it to honda and have them align it and adjust the camber as well?
Old October 3rd, 2007, 12:55 AM   #5
Bobby Lane Racing
honda will charge you an arm and a leg. take it to an allignment shop
Old October 3rd, 2007, 12:56 AM   #6
Senior Member
nicepeta's Avatar
never ever ever ever and ever go to Honda...lol
Old October 3rd, 2007, 12:56 AM   #7
I'll try looking up one in the phonebook tomorrow. Damm soo many things going wrong right now. sighs...
Old October 3rd, 2007, 01:10 AM   #8
Old Member
Du3ce's Avatar
you probably set them differently than the other thats why its swaying like that
Old October 3rd, 2007, 01:52 AM   #9
*this space for rent*
UrbanRocker's Avatar
Send a message via AIM to UrbanRocker
also, make sure that the ingall's camber kit is tightened. That happened to me when I installed the rear camber kit on my TSX. Just had to retighten it and everything was back to normal.
UrbanRocker is offline   Reply With Quote Quick reply to this message
Old October 3rd, 2007, 03:39 AM   #10
M90SC Boosting 13PSI
NVA-AV6's Avatar
LT,
Find an alighnment shop that deals with droped cars with camber kits, I have seen regular shops screw things up more because they did not know what to do with the suspension, especially on a car with coilovers when you need to set ride height for each corner. Also if you do have coilovers, get the car corner balanced.
Old October 3rd, 2007, 09:35 AM   #11
Originally Posted by NVA-AV6 View Post
LT,
thanks for the info paul! gonna call and ask around today!
Old October 3rd, 2007, 12:37 PM   #12
well i dropped it off so it can be aligned and balanced, hopefully all goes well!!!
Old October 3rd, 2007, 01:25 PM   #13
hella flush
lilfotoman's Avatar
i had that problem before, the alignment shop forgot to do change my toe, so it was swerving back and forth.
Old October 3rd, 2007, 09:04 PM   #14
oSCaR
v6_ccord_2k5's Avatar
LT,
dont you need adjustable top mounts to get a car corner balanced?
Old October 4th, 2007, 10:40 AM   #15
well the shop couldn't do my alignment, my car was too low so they couldn't even put it up on the machine, so that was pointless, but later that night me and my dad worked on it and all good now!!! no more swerving, had to adjust the toe.
Old October 4th, 2007, 10:45 AM   #16
NVA-AV6's Avatar
No....
Old October 4th, 2007, 12:03 PM   #17
J35A2K23B18CSRDETT2JZLOL
SIRSIG's Avatar
your camel toe smells fishy. lol! j/k
yeah, just like the rest said, go to non-Honda shop for alignment/adjustment and you'll be good. 'Have to do it soon cause it might damage something on your car.
SIRSIG is offline   Reply With Quote Quick reply to this message
Old October 4th, 2007, 12:47 PM   #18
Envious of J35's
AcCoCuOpReD-04's Avatar
Take off the front bumper and they should be able to get it on the lift for a 100% spec alignment jobby
AcCoCuOpReD-04 is offline   Reply With Quote Quick reply to this message
Old October 4th, 2007, 01:37 PM   #19
DV8
Hella Functional
DV8's Avatar
Umm....
You really can't "adjust" your own camber and get adjust your own alighment. The degree of change is so minuscule, that you really can't pick up with your eyes. But it will EAT through your tires.
Get it done right the first time, there are PLENTY of alignment shops out there that can do this, and work on lowered vehicles. They do alignments with lasers, and all kinds of other goodies. So you really should get it done professionally.
Speaking from experience....
Old October 11th, 2007, 01:59 AM   #20
AHo
when i took my car to a shop the guy couldnt adjust one of my front balljoints because it was too tight for him. i went home to loosen it myself and slid it to what looked correct. when i took it in he was like "wow its right on spec" yeah i know i was lucky
i had to look at like 3 shops before i found a new ntb with new equipment that had an alignment rack in the ground. i couldn't get my car on a regular rack because the part that swings down to lift up the car would hit my subframe. but yeah seriously take your car to a shop with a lift in the ground to get it alligned correctly.
AHo is offline   Reply With Quote Quick reply to this message
