Rims & tires question - Honda Accord Forum : V6 Performance Accord Forums
Old November 19th, 2007, 07:17 AM   #1
Senior Member
nicepeta's Avatar
anyone knows whats the maximum and minimum offset for 7 gen accord if i want the rim of 19 X 8 ???
and does anyone knows any light weight 19 X 8 rims???
nicepeta is offline   Reply With Quote Quick reply to this message
Old November 19th, 2007, 09:11 AM   #2
MADE IN THE PHILIPPINES
aV6Pinoy's Avatar
go with atleast a +40 offset with that 8'' wide. don't go lower than that. i dont really know which ones light.
with your car's power, i would buy a 17 inch light weight wheel. with nice beefy tires.
aV6Pinoy is offline   Reply With Quote Quick reply to this message
Old November 19th, 2007, 03:16 PM   #3
Senior Member
nicepeta's Avatar
cuz the rims i have for now is 19 X 8 offset 35
but its 27lb each rim!!!!
Old November 19th, 2007, 04:07 PM   #4
aV6Pinoy's Avatar
damn, that's heavy.
with that offset. go with 225-35. don't drop too low and you should be fine. just watch out for the pot holes and drive carefully.
Old November 19th, 2007, 04:15 PM   #5
Senior Member
nicepeta's Avatar
so whats the max? 45 offset?
cuz i found a rim that is cheap and light but the offset is 48...
is that bad?
Old November 19th, 2007, 04:31 PM   #6
Bobby Lane Racing
nighthawk04v6's Avatar
i have 19x8.5 +45, my wheels are like 22lbs each, with tires is about 46lb each. for an 8 inch wide wheel, i'd recommend a 40 offset.
Old November 19th, 2007, 04:42 PM   #7
A n g u s D e i
itchthys's Avatar
Send a message via AIM to itchthys
I TOLD YOU!! They're heavy!! Hahaha!
Just get 18s, Peter! Some.. VOLKS. Pwhaha
  • [ Car Domain. Check it out. ]
&mpt=[CACHEBUSTER]">
  • [ DIY Ingalls Rear Camber Kit ]
itchthys is offline   Reply With Quote Quick reply to this message
Old November 19th, 2007, 05:21 PM   #8
Senior Member
nicepeta's Avatar
LOL wanna sell me yours?
Old November 19th, 2007, 05:22 PM   #9
Senior Member
nicepeta's Avatar
it wont rub??
for 8.5 with the 45 offset...
so if i get 8 with 48 offset, it should be fine right?
Old November 19th, 2007, 05:33 PM   #10
neeeeeeeeeeeeeeeeeeeeeeel
implayaz9's Avatar
should be fine
Old November 19th, 2007, 05:36 PM   #11
A n g u s D e i
itchthys's Avatar
I might be selling mine.. for like 650$.. >: )
Old November 19th, 2007, 07:20 PM   #12
Senior Member
nicepeta's Avatar
will Bolt Pattern: 5-112 fit our 7gen?
Old November 19th, 2007, 07:26 PM   #13
implayaz9's Avatar
nope!
Old November 19th, 2007, 07:36 PM   #14
Senior Member
nicepeta's Avatar
so it has to be 5-114.3?
but i remember the one i have is 5-120...
Old November 19th, 2007, 08:08 PM   #15
346hp/300tq @ 4psi
04accordcpe's Avatar
nope
nicepeta so it has to be 5-114.3?
but i remember the one i have is 5-120...?
yes, no
is that bad?
no, no,
it wont rub??
depends on drop,
poor peter you remind me of a lost little puppy. i dont think ive ever seen you post without a ? mark somewhere in there lol. dont take it personal, just busting your chops a little bit thats all
nicepeta cuz the rims i have for now is 19 X 8 offset 35
that is heavy! BUT.... if you did a little research, before jumping into things, you wouldnt be stuck with them, no what i mean? its like studying before a big test.
volks are the way to go if you want some lightweight 19 inch wheels, but they are $$$
i am slammed on my 19x8, 45 offset, Racing Harts with 235/35/19's and its litterally 1-2 mm from rubbing in the rear. if you get 8 wide, you can go as low as 40 offset IMO, but you will either have to roll your fenders or ride around with mad camber. those were the 2 things i looked into before choosing a size. all that info is here, just gotta search dude.
BTW, you can get a closer look at crispy creme tomarrow see you there
Old November 19th, 2007, 08:22 PM   #16
Senior Member
nicepeta's Avatar
the one i have for now is 19 X 8 35 offset 5-120
Old November 19th, 2007, 08:50 PM   #17
346hp/300tq @ 4psi
5-120 eh? uhhh ok.....if you say so. iirc you have ACE wheels right?. i think their whole line of wheels are on the heave side. expect to pay at least double for a set of 19 inch light weight. or just get some 18 inch if your more worried about performance
my Racing Harts are 21bs ea, which isnt bad for 19's. with tires, their about 45.8lbs on a digital scale. thats still a pound lighter than my 6spd wheels with tires (46.5), but you cant get around rotational mass.
Old November 19th, 2007, 08:54 PM   #18
A n g u s D e i
itchthys's Avatar
Dude get some 18's man.. shave the lbs on the rims AND the tires.
Make your car go zoom!!!!!!!!.. not like.. zz.........ooooo .. .. .mmmm~
Old November 19th, 2007, 11:51 PM   #19
i got a enkei RPF1 19"x 8 offset:48 5 x 114.3 73 18.7 lbs.
on RE050A 225/40/19
very stable for fast cornering
df2pika is offline   Reply With Quote Quick reply to this message
Old November 20th, 2007, 01:25 AM   #20
Bobby Lane Racing
17" traklites!
Old November 20th, 2007, 02:08 AM   #21
Senior Member
nicepeta's Avatar
will 19 X 8 with 48mm offset with 235/35/19 tires with 1 finger gap fit in 7gen without rubbing?
Old November 20th, 2007, 02:23 AM   #22
A n g u s D e i
itchthys's Avatar
Peter, whats the dealio with you and 19s?
Old November 20th, 2007, 05:12 AM   #23
Senior Member
nicepeta's Avatar
i like bigger wheels..i duno..
so will 19 X 8 with 48mm offset with 235/35/19 tires works?
and the especailly my tires are new, why paying more for another set of tires?
i will rather use that money to buy myself a bigger lighter rims!
Old November 20th, 2007, 09:31 AM   #24
Bobby Lane Racing
buy a set of 17's and a big brake upgrade infront.
Old November 20th, 2007, 10:50 AM   #25
A n g u s D e i
itchthys's Avatar
Bigger wheels won't help you in the long run.
You can sell the tires longside the wheels..
Old November 20th, 2007, 11:34 AM   #26
346hp/300tq @ 4psi
^^ so you not read what i post? or do you think im blowing smoke up your a$$? why dont you read what i type?? \/
if i can slam my car with no rubbing issues with 19 x 8 45 offset, what makes you think a 48 offset will?
Old November 20th, 2007, 11:43 AM   #27
Doc
J35S004
Doc's Avatar
Originally Posted by aV6Pinoy View Post
...with your car's power, i would buy a 17 inch light weight wheel. with nice beefy tires.
I agree, aV6Pinoy.
NP, My 17x8 Gram Lite 57s' weigh in around
16lbs each. I picked up a set with 235/45
Avon Tech M500s (awesome skins btw) for
about 18 hunj from Tirerack.
Doc is offline   Reply With Quote Quick reply to this message
Old November 20th, 2007, 05:01 PM   #28
joedanger11's Avatar
to answer your question, it will work. you will rub if you're slammed.
I was on 19 x 8.5 50+ offset with 245/40/19, so there was a lot of rubber, and I didn't rub at stock height. With a modest drop, you should still be ok.
i'm dumped on tein ss now and have 225/35/19 in the front, 235/35/19 in the rear with rolled fenders and i don't rub. no camber kit.
Old November 20th, 2007, 06:43 PM   #29
Senior Member
nicepeta's Avatar
what do you guys think of this one?
SSR wheel
19X8 48offset 19.5lb
and its only $300 each wheel
Old November 20th, 2007, 07:25 PM   #30
A n g u s D e i
itchthys's Avatar
Too bad they look like !!!!!!!!!!!!!!!!!
lol jk. Get that powercoated into like bronze and it'll look HOT, but that's just me.
Hey, those are not bad. But if you got them in 18s.. I'm sure they'll be cheaper AND lighter. pwahha!
