Spark Plugs - Honda Accord Forum : V6 Performance Accord Forums
Old January 17th, 2011, 06:54 PM   #1
wht_on_blk
blk_on_blk's Avatar
Spark Plugs
Hi, I'm looking for the best company that makes performance spark plugs and wires, for the '03 - '07 V6 accord... any suggestions?
blk_on_blk is offline   Reply With Quote Quick reply to this message
Old January 17th, 2011, 08:53 PM   #2
Just run OEM spark plugs. They are as good as they get. They are either Denso or NGK. The car use coil packs so it doesn't really matter about wires. IF you really want to upgrade them they will set you back 900 bucks. Plasma coil ignition system.
Old January 17th, 2011, 08:59 PM   #3
DAT Dewd from Dallas MANG
yo...
nex spark plugs are available... but only if you have serious intake manifold mods or cams or boost would i recomend them...I would just get ngk or denso iridium plugs...they re like 10 to 13 bucks a piece but well worth it....
Old January 17th, 2011, 09:14 PM   #4
Your V6P Snake Champion
oswhiteboy's Avatar
Not another spark plug thread...
oswhiteboy is offline   Reply With Quote Quick reply to this message
Old January 17th, 2011, 10:26 PM   #5
Shockfire10's Avatar
I went with Denso Platinum TT Spark Plugs. Great plugs and cheap.
Shockfire10 is offline   Reply With Quote Quick reply to this message
Old January 17th, 2011, 10:47 PM   #6
got those also. not bad for the price
Old January 18th, 2011, 02:06 AM   #7
lol i'm also in the market for spark plugs and most likely will get NGK laser Iridium part# 6994.
thaialism is offline   Reply With Quote Quick reply to this message
Old January 18th, 2011, 02:19 PM   #8
I don't know much about Accords but S2000s always have issues with anything else other than NGK. I think NGK is the best brand for Hondas. IMHO, changing plugs and stuff like that for performance is not worth it. It's best to just put OEM. If you are in a hotter state, just put one step colder plugs and call it a day.
Just my .02 cents
S2K_MoZo is offline   Reply With Quote Quick reply to this message
Old January 18th, 2011, 07:31 PM   #9
oswhiteboy...you crack me up...that's what I was thinking too..
but defintiely...NGK plugs are awesome....NEX ones aren't bad either....
Old January 18th, 2011, 08:16 PM   #10
Denso is also OEM. Mine had Denso on them.
Old June 8th, 2013, 08:37 PM   #11
Hate to bump an old thread but Ngk doesn't make 1step colder for 7thgen accords. So would a different vehicles plugs that are 1step colder than our oem work? If so what vehicle. I found these but will these work? NGK Iridium Spark Plugs (4 Spark Plugs) | BKR8EIX | Spark Plugs | Universal | K Series Parts
Chaosta is offline   Reply With Quote Quick reply to this message
Old June 8th, 2013, 08:39 PM   #12
go with W/E is one step colder for RSX.
Old June 8th, 2013, 08:44 PM   #13
So 7th gen v6 accord have same heat range as rsx's?
Old June 8th, 2013, 08:47 PM   #14
nismoasfuh's Avatar
Denso>ngk imo
Old June 8th, 2013, 08:51 PM   #15
Well I'd go with denso. If they made one step colder lol . Ngk and denso are the same IMO
Old June 19th, 2013, 12:54 AM   #16
Mr. Detail
Scottwax's Avatar
OEM in mine were Denso, replaced them with NGK iridiums. Working just fine with the new plugs. Idle was a touch smoother but I had over 120k on the original plugs.
Old June 19th, 2013, 03:37 PM   #17
Originally Posted by oswhiteboy View Post
not another spark plug thread...
lol.
2006 Black Accord V6-speed
AEM V2 intake
Neuspeed Rear Sway Bar
curyfed is offline   Reply With Quote Quick reply to this message
Old October 11th, 2014, 05:44 AM   #18
I have 2005 4 cyclinder and nearing 70K. I have the manual and would like to just stick w/ OEM. Any body have suggestions? If I'm not mistaken, the manual says I don't have to change till about 100K?
Battery is offline   Reply With Quote Quick reply to this message
Old October 11th, 2014, 05:05 PM   #19
The name is Z
CrackerTeg's Avatar
I changed mine at 110k but that's mostly because I felt like doing it and not because it needed it. When I checked the plugs, they honestly looked like they could go another 40k easily.
