will 20mm spacers clear oem studs? - Honda Accord Forum : V6 Performance Accord Forums
Old August 15th, 2014, 04:35 PM   #1
for those of you guys who runs spacers..i want to run 20mm spacers..the hubcentric ones with the studs already pressed in..my wheels have the cavities on the back..problem is they are dual drilled 4 and 5x114.3..i dont think all the studs will line up in the spaces behind my wheels if they are sticking out past the spacer..so i need spacers that will clear the studs so the wheel sits flush..any experiences?
jpez24 is offline   Reply With Quote Quick reply to this message
Old August 15th, 2014, 04:39 PM   #2
Hmmm you might need to grind down the bolst from the hub or get shorter ones
mdozard32 is offline   Reply With Quote Quick reply to this message
Old August 15th, 2014, 05:14 PM   #3
DreaminAccord's Avatar
I have run 20mm & 25mm H&R hubcentric spacers before with absolutely no issues. The OEM studs barely stick out on the 20mm+ spacers as they're a lot thicker than say a 5mm spacer... you should be okay but worst case scenario, if you have clearance issues see (beforehand) if the spacers are refundable? If not, sell 'em on CL or the forums
H&R P/N for 20mm (on LEFT):
Ben
(Sold 7/26/17)
(Purchased 5/18/17)
Old August 15th, 2014, 05:32 PM   #4
your the effin man..i think ill run the 25 mm just to be safe..thanks
Old August 16th, 2014, 02:04 AM   #5
welcome buddy
Ben
(Sold 7/26/17)
(Purchased 5/18/17)
