k24 engine swap - Honda Accord Forum : V6 Performance Accord Forums
Old September 6th, 2014, 05:34 PM   #1
CeRtiFiEd PimP
k24 engine swap
Looking to swap my engine due to burning oil. What year is the best to swap out with, or what other motor would be the best plug and play swap. Would a tsx swap work with my i4 5 speed?
Old September 6th, 2014, 05:37 PM   #2
Evan
Mass4banger's Avatar
the only plug and play option is another k24a4. A tsx motor will require engine management such as kpro or ktuner
Mass4banger is offline   Reply With Quote Quick reply to this message
Old September 6th, 2014, 05:55 PM   #3
CeRtiFiEd PimP
is that the only thing i would need? how much would a engine management cost?
Or is a engine rebuild better by replacing all the piston rings, gaskets ect?
Old September 6th, 2014, 10:07 PM   #4
757Accord's Avatar
Depends on your budget. But easier to just find the same motor and drop it in.
757Accord is offline   Reply With Quote Quick reply to this message
Old September 6th, 2014, 10:46 PM   #5
^ k24a1 might be a good choice also if you have a cable throttle. Its from a CRV and you can always add a k20a2 head later down with kpro
or just get a stock motor for ease of installation
Old September 7th, 2014, 08:07 PM   #6
CeRtiFiEd PimP
could be it something else, would a compression and leak test help diagnosis? Oil light comes on after 3100 miles so its burning pretty fast, i had to change my o2 sensor and there is black gunk in the exhaust pipe
Old September 7th, 2014, 08:07 PM   #7
also do a leak down test
Old July 21st, 2015, 09:41 PM   #8
CeRtiFiEd PimP
What year engine will work, will 2007 fit my 2003?
Old July 28th, 2015, 12:31 PM   #9
it will "fit" physically.
14J35Y2 is offline   Reply With Quote Quick reply to this message
