2003 accord help plz!! - Honda Accord Forum : V6 Performance Accord Forums
Old September 12th, 2014, 09:56 PM   #1
hiphop23j's Avatar
Today i went to a radio shop to have a remote start/alarm and fog lights installed. My car a 2003 accord v6 spd went in fine with no problems or check engine light on. After several hours they told me something is wrong, right when you turn the key to the on position with out starting the car the driver side fan comes on and the temperature gauge goes in the the full hot zone. The fan stays on the whole time even when you turn on the car, the temp stays hot as well, the gas pedal when pressed does nothing. Check engine light is on and throws low voltage codes i dont remeber the codes. They check everything with a volt meter and everything is fine , they recheck there work and seems to be fine. lastly they opened the ecm and said one chips smells like its burned, could the ecm cause this issue? i had to leave my car at the shop so they could work on it tomorrow, any insight or suggestion please.
hiphop23j is offline   Reply With Quote Quick reply to this message
Old September 17th, 2014, 12:13 PM   #2
hiphop23j's Avatar
The shop fixeed it, the ecm was fried smh.
Old September 17th, 2014, 01:49 PM   #3
accord325's Avatar
I was going to say it seems like the shop shorted something out an should replace the ECU for you. Glad they did it for you
Old September 17th, 2014, 03:10 PM   #4
Bobby Lane Racing
nighthawk04v6's Avatar
Most alarm guys are hacks and will take power from any source they can.
Old September 17th, 2014, 09:32 PM   #5
hiphop23j's Avatar
it was crazy im sure they did that, then they tried to say the car came just did that on its own and if i had rodents that might chew the wire smh, i looked at him like he was crazy, shops barely touch my car because i feel like they don't care and just do anything to get paid.
