Couple questions - Honda Accord Forum : V6 Performance Accord Forums
Old January 28th, 2015, 07:26 AM   #1
Couple questions
Hello all. I have searched but no answers so I am posting here, hoping someone will understand my description.
Ok I have a 04 Accord Coupe 6 speed 6 cyl, and occasionally, not always, in first, second and third, at the end of letting the clutch out, right as it engages, there is a slight skip sort of feeling.. kind of like a duh duh duh right as it engages. It only does it occasionally, though, and NEVER with any mechanic riding with me. One friend suggested I check the hydro fluid in the slave cylinder and that looked fine. Clutch does not slip at all, and will light them up with no issues, just occasionally get that studder.
Has anyone else ever had this happen? Am I describing it right well enough to understand?
Second question is I was looking for an auto dimming side mirror, but could not find one. Where I live there are a LOT of trucks and the lights reflected in the side mirror are annoying as hell. Was to the point I asked a tint guy to tint it for me.... who looked at me like.... umm da%$&?? I see some of the mirrors for newer accords will swap and they have the turn signal in it, and are heated, and thats all nice but I want one to dim, so I dont have to keep turning it then turn it back in the day.
Any suggestions?
Thanks guys
hightechredneck is offline   Reply With Quote Quick reply to this message
Old January 28th, 2015, 11:19 AM   #2
M90SC Boosting 13PSI
NVA-AV6's Avatar
Bushings in your flywheel.......
Old January 28th, 2015, 11:29 AM   #3
It's the check valve. Look up how to delete the check valve. It delays the clutch engagement
Old January 28th, 2015, 11:56 AM   #4
So its normal?
Ill have to check that Thanks... I was fearing a new clutch and flywheel and whatever else inside there that should be swapped once its out...
I have so many parts I have bought (many off the forum here) that are sitting WAITING until spring.... Come on spring...
