How do you crank the engine without starting it? - Honda Accord Forum : V6 Performance Accord Forums
Old February 16th, 2015, 05:20 PM   #1
Calm like a bomb
StevilKnievel's Avatar
This is the first car I've owned without a distributor. So my question to you is, how do you crank the engine without having it start? 05 V6 AT.
Old February 16th, 2015, 05:22 PM   #2
pull the fuel fuse. its in the lower driver side kick panel
Old February 16th, 2015, 05:25 PM   #3
Calm like a bomb
Simple enough. I assume this will do the same as pulling the ignition coil wire on a vehicle with a distributor?
Old February 16th, 2015, 07:31 PM   #4
M90SC Boosting 13PSI
NVA-AV6's Avatar
Jump the smaller wire going to the starter to battery positive, doing it this way will not power the injectors or coils and will purely spin the engine.
Old February 16th, 2015, 08:01 PM   #5
kinda the same, but there will not be fuel there to flood the engine. If you pull the coils I think gas still sprays. Thats what I do to get the crank pulley off when I do pulley swap or timing belt
Old February 16th, 2015, 08:09 PM   #6
The Jester
Pull the fic fuse under the hood if you're okay with ecu resetting. I think this eliminates the flooding issue as it shouldn't activate anything injecting related.
Old February 17th, 2015, 07:46 AM   #7
Calm like a bomb
With the fuse pulling method, does this eliminate power to the injectors because I don't want to burn those suckers out.
@NVA-AV6 - last time I messed around near a starter without disconnecting the power I got a good jolt. Your method seems to be the best way to eliminate a chance of flooding or burning out the injectors but scares me for the fact that its easy to get it wrong. You have a method for this or some kinda hack?
Old February 17th, 2015, 09:06 AM   #8
NVA-AV6's Avatar
ONLY MESS WITH THE STARTER SIGNAL LINE, not the battery connection. Also one of these helps.
http://www.summitracing.com/parts/an...n-IaAryj8P8HAQ
Clamp one end to battery + and on mine I chopped off the other clamp and crimped on a female spade connector to connect to the starter.
How's that hope and change working for you???
Old February 17th, 2015, 10:55 AM   #9
Calm like a bomb
I shall be purchasing one of these immediately!
Old February 17th, 2015, 12:33 PM   #10
Calm like a bomb
[IMG]&mpt=[CACHEBUSTER]">[/IMG]
I am assuming the connector marked "C" is the one you remove, hook the spade connector to and jump from the pos+ battery terminal?
Old February 17th, 2015, 02:15 PM   #11
NVA-AV6's Avatar
Correct.
