J32 swap plans - Honda Accord Forum : V6 Performance Accord Forums
Old April 23rd, 2015, 02:07 PM   #1
Strath's Avatar
J32 swap plans
So the guy selling me the supercharger ended up selling his car as a whole . So I think I'm gonna do a stroker j32a3. Was wondering what is required in entirety to swap a j32a3 in place of a j30a4 on a 2003 sedan v6 5AT EX-L sedan. Paul's input here would be useful if you're around :P Found out these engines are only like 500$ on ebay. Pretty dope gains for only 500.
Also what parts would be needed for a stroker build on 87 octane?
Also Also is there a difference between the 2004-2005 3.2 engine and the 06 07 08 TL 3.2?
Strath is offline   Reply With Quote Quick reply to this message
Old April 28th, 2015, 12:56 AM   #2
Bolted mine straight in... I have 2004 honda accord 6speed got the same year motor and was plug and play basically
J32a3NightHawk is offline   Reply With Quote Quick reply to this message
Old April 28th, 2015, 01:19 AM   #3
The Jester
Hardest part is getting the transmission remounted to the new one. And swinging out our transmission/getting the car high enough to slide it out.
Old April 28th, 2015, 05:05 AM   #4
M90SC Boosting 13PSI
NVA-AV6's Avatar
04,05,06 J32 are the same, 07,08 new design bell housing.
Pull the engine and trans as a single unit out the top, then separate out of the vehicle. Before dropping the new engine into the vehicle replace the timing belt and water pump (soo much easier while it is out.) Also check the rear main seal, replace if any signs of leaking or weeping.
Old April 28th, 2015, 09:15 AM   #5
05accord6spd's Avatar
What are you planning on doing to the j32 ? A j36 build?
Old May 7th, 2015, 06:08 PM   #6
how did you bypass the immobilizer? Just recently did a j32a3 swap in my 03 coupe. kept the j30 ecu in because I couldn't find a j32a3 6 speed ecu, they were all autos. finally picked one up a few weeks ago but haven't swapped it in because of the immobilizer.
spectre86 is offline   Reply With Quote Quick reply to this message
Old May 7th, 2015, 07:50 PM   #7
get the honda hds programmer or tow it to honda. You will need the tool. No way around it.
Old May 18th, 2015, 03:16 PM   #8
damn... was hoping someone had a way.
Old June 1st, 2015, 04:13 PM   #9
Went into the local dealership and explained to them about the swap. they said a Honda scan tool cant read an Acura ECU and I would have to go to an Acura dealership.
Is this true? the nearest acura dealership is over an hour away.
Old June 1st, 2015, 04:18 PM   #10
It isn't true. You need to find a tuner friendly dealership to hook you up or buy a fly100/HDS to do it yourself.
Old June 1st, 2015, 04:57 PM   #11
so a Honda scan tool will no problem if I just took it in and told them to hook it up?
I think they might really believe that it cant read becauase one of the service techs had a turbo k20 civic lol.
Old June 1st, 2015, 06:20 PM   #12
The acura j32a3 and honda j30a4 ecus are almost identical. I hooked up to both without issue using the HDS tool.
Old June 1st, 2015, 06:46 PM   #13
@spectre86 if you need to borrow one I will be getting another one since someone decided to keep my fly100 and laptop. He never reply back to my text or call. so w.e
Old June 5th, 2015, 10:24 AM   #14
sweet. Good to know. Looks like Ill go back and bother the dealership. thanks for the info.
Appreciate the offer. I couldn't ask to do that, specially since you just had some ass take yours. I honestly don't know how to use a fly100. lol
Old June 5th, 2015, 10:49 AM   #15
I made a video on how to do it
Old June 9th, 2015, 05:54 PM   #16
You have a link? I don't mind paypaling you some cash to use it if its something easy that I can do.
Old June 9th, 2015, 07:47 PM   #17
I will pm you the link tomorrow. It's hidden. I need to rekey my spare keys to my car again. Since the first time I only had 1 instead of all the set.
So I will make a new video
Old June 24th, 2015, 05:57 AM   #18
What better j3aa4 or j32a2?
sasa is offline   Reply With Quote Quick reply to this message
