Valve adjustment specs for v6 - Honda Accord Forum : V6 Performance Accord Forums
Like Tree7Likes
  • 1 Post By thisaznboi88
  • 2 Post By accord325
  • 1 Post By NVA-AV6
  • 1 Post By CBUS-AV6MT
  • 1 Post By StevilKnievel
Old May 4th, 2015, 06:44 PM   #1
Here are the valve adjustment specs for the V6 accord
intake 0.20-0.24mm or 0.008-0.009in
exhaust 0.28-0.32mm or 0.011- 0.013in
here is the cylinder order
Fire wall (towards cabin)
1_____________2_____________3
4_____________5_____________6
Radiator (towards front bumper)
Now as far as tight and loose end I have no idea. Anyone want to chime in on this.
StevilKnievel likes this.
Old May 4th, 2015, 07:56 PM   #2
accord325's Avatar
I personally use the "next size up" trick.
Example - Intake has +-.02", meaning .24" is the max. I will use a .22" to feel, and then use a .24". If the .24" does not go in, then your within spec. I think mine is .238" or something like that. I would have to go break them out.
Or, if you want to favor the tight side, use a .20" and then a .22" as the "Next up"
NVA-AV6 and thisaznboi88 like this.
Old May 5th, 2015, 12:02 AM   #3
The Jester
Benefits of favoring tight side or loose side?
Old May 5th, 2015, 05:34 AM   #4
M90SC Boosting 13PSI
NVA-AV6's Avatar
I always like it on the tight side, LOL. Seriously thou it will stay in adjustment for longer and you will get slightly more valve opening. The tappets do mushroom over time and the cam lobes do wear, this is why it goes out of spec over time.
Now there will be those who say why not just adjust it with 0 clearence, that is a good way to get "valve float" at high rev where the valves will be left just slightly open. This will destroy both the edge of the valve and the seat as well as cost power.
thisaznboi88 likes this.
How's that hope and change working for you???
Old May 5th, 2015, 12:37 PM   #5
Calm like a bomb
StevilKnievel's Avatar
I've been debating doing this opposed to having it done for me for a few weeks now. I know ALL hondas have that little tick but I feel it might be time for mine to be serviced. Any idea what the jobber rate would be on this type of service?
Old May 5th, 2015, 01:45 PM   #6
3 hours. the manifold and a whole bunch of **** have to come out. Its also a good time to swap out those gasket and install an MDX spacer or something while you are down their.
Old May 5th, 2015, 02:39 PM   #7
Calm like a bomb
I haven't torn into this engine too much yet so I don't know the intricacies of it yet. I'm going to be doing my timing belt etc. soon. Will removing those components get me pretty close to home with the top of the heads for this job?
Old May 5th, 2015, 02:41 PM   #8
timing belt is on the side. You will still need to take off the intake manifold and valve covers.
Old May 5th, 2015, 02:49 PM   #9
accord325's Avatar
I've done timing with the IM and valve covers on the car. Why do you say that, brother?
Point A to B
NA.... Till I Spray
Old May 5th, 2015, 02:51 PM   #10
Calm like a bomb
I think he meant that they don't have to come off to do the timing kit. BC I was asking if that would already be torn down to get access to it. I need a rental car for a week so I can disassemble the top end and get to know her better.
Old May 5th, 2015, 03:00 PM   #11
accord325's Avatar
How many miles on your car? I did mine at 120k miles and I believe the exhaust were a hair loose (or intake, dont recall). That was with a lot of hard driving, track days, etc.
Post a video if you can.
Point A to B
NA.... Till I Spray
Old May 5th, 2015, 03:53 PM   #12
Calm like a bomb
As close to 110 as makes a difference. I'll get a vid up probably tomorrow. Sound quality isn't great though so I'm not sure it will help. It isn't bad IMHO but I am the kind of person who will change/fix/upgrade anything in the immediate vicinity of something I'm already changing/fixing/upgrading. That's why I'm always broke lol! Plus there is a piece of mind that comes from knowing a potential issue has been addressed before it becomes major.
Old May 5th, 2015, 03:57 PM   #13
intake get loose. Exhaust get tight
Old May 5th, 2015, 05:33 PM   #14
accord325's Avatar
Same here. I think it's a good practice, but at 120k my water pump was flawless, timing belt looked brand new and the valve were in spec. LOL. Ohh well.
Point A to B
NA.... Till I Spray
Old May 5th, 2015, 06:10 PM   #15
I left out to do the valve adjustment. Internet cut off.
Old May 5th, 2015, 06:42 PM   #16
stalloutboy's Avatar
Valve adjustment is easy but time consuming imo. The biggest job I ever did before doing a valve adjustment was changing my shocks
stalloutboy is offline   Reply With Quote Quick reply to this message
Old May 5th, 2015, 06:42 PM   #17
Ive done my valve lash twice. First time I made a few worse as the firewall side is a ***** to do. I'd recommended buying two sets of feeler guages and putting a 45 degree bend in one about 3/4" inch from the end to make it a lot easier. Or buy the ones that already have the bend. The second time I went through it was a lot smoother doing that.
If you take the plugs out it is much easier to turn the crank but not necessary.
accord325 likes this.
Old May 6th, 2015, 04:11 AM   #18
The Jester
I remember there being some backwards way of using the valve lash to slightly enlongate or shorten the overlap on the cams by either being on tight side (or slightly over) or on the loose side (or slightly over), have you found any results from this? Something like tighter runs leaner looser richer? May have that backwards.
I will say valves are a bit of an intimidating project just due to needing to pull the intake manifold and everything connected on, and you're messing with the cam, and need the car with the tire off, but once you get past the two dozen bolts attaching this all it's really just double checking your work. The "size up" method is a good one. As is a fresh set of gauges, and a long boxend 10/flathead with a wide handle. Or if you get the actual tool it makes adjusting much more sure.
Definitely worth being able to check and adjust accurately though, being able to detect and repair an engine issue or anomaly by knowing what having too loose of a valve lash sounds like vs correct can be the difference between replacing two dozen valves thinking they're bad and replacing a bolt.
I would rather pull my heads off than try to swap springs or shocks again. And pulling the heads off costs a hundred in gaskets to do right.
Either get a prebent set and regular straight or bend one yourself, I almost use mine at a 90 on the fronts, the firewalls I would say to triple check, and find a good way to get accurate back there as they're just as important to be accurate in adjusting the EXACT (+-.002mm) same distance that you adjusted the front bank, but are at a weird angle. Your arm doesn't fit right, you cant look at the valves dead on, you can't really get a good angle on cyl 3, and the engine is tilted toward the firewall making the space even more awkward.
Overall, do it, get the angled feelers, make sure the feelers have the right increments, boxend 10mm, big handle flathead, 3/8" entender, carb clean for your runners/IM(optional), and don't plan for it to be a quick one hour on off. 1hr doable, with power everything, all of the specialty tools, and knowledge of the feelers, not recommended.
Old May 6th, 2015, 08:43 AM   #19
Calm like a bomb
Here is a video. Please excuse the dirt and debris in the IM.
&mpt=[CACHEBUSTER]">
Old May 6th, 2015, 09:52 AM   #20
accord325's Avatar
It may be a little loud, but sounds okay. I have a thinner wall DTB IM, Ported heads and thinner PCD's making my $hit sound loud, about the same as yours. Drove me crazy for a while till I finally came to the conclusion I did everything right and that is just how it sounds.
Old May 6th, 2015, 11:53 AM   #21
You should be okay. Doesn't hurt to do a valve adjustment. I checked mine a while back and they were off by a little after 10k of driving.
Old May 6th, 2015, 12:15 PM   #22
Calm like a bomb
I've been in there with a mechanics stethoscope and didn't hear anything abnormal. The tensioner pulley makes a LOT of noise so some of what you are hearing is that. Like I said, I know they all tick but sometimes I THINK I hear something out of whack but that's just me looking for trouble. I'm going to get to this eventually. I need to figure out ALL the components that should/can be replaced in the process like gaskets and such and just dive in.
Old May 6th, 2015, 12:18 PM   #23
sounds like a good plan.
Just a heads up it usually takes me 2-3hours do to the valve adjustment. Its hard to explain how to do it, but you just got to do it and get "feel" for it. There is a certain amount of drag you want.
Old May 6th, 2015, 12:29 PM   #24
Calm like a bomb
I know exactly what you mean. I'm no stranger to engine teardowns and rebuilds but I just haven't gone into this engine yet and being that it's my DD I must be careful so I still have a ride to work lol. I appreciate everybody's input here, thanks guys. I will probably do a write-up when I get around to doing it.
Old May 6th, 2015, 12:34 PM   #25
here is some help along the way
https://www.youtube.com/watch?v=OnyqVg3nWRk
https://www.youtube.com/watch?v=iLdgivYwUiQ
Old June 24th, 2015, 06:03 AM   #26
Thank you very much!
sasa is offline   Reply With Quote Quick reply to this message
