What mileage to replace second timing belt at on '04 v6 automatic? - Honda Accord Forum : V6 Performance Accord Forums
Old August 27th, 2015, 08:37 AM   #1
I had the timing belt / waterpump done around 105k miles / 168k KM on my 2004 V6 automatic Accord Coupe.
At what mileage should I be looking at replacing it again? Car currently has 154k miles / 248k KM.
1999 Camaro SS 6-speed Coupe
2004 Accord EX-L V6 Auto Coupe
kingrukus is offline   Reply With Quote Quick reply to this message
Old August 27th, 2015, 09:32 AM   #2
J30 LSD
flylow2cre8's Avatar
Hi kingrukus, You probably won't need to replace it again for another 50k-60k miles (roughly 80k-96k KM). Did you also have your accessory drive belt replaced?
Other regular maintenance parts to consider replacing/inspecting the next time you replace the water pump and timing belt is the timing belt hydraulic tensioner, idler pulleys, accessory belt automatic tensioner, front camshaft seals, front crankshaft seal, to name a few....
Old August 27th, 2015, 02:17 PM   #3
Carpe Diem
ikethegreat's Avatar
Every 100k or 7 years, whatever comes first.
Old August 27th, 2015, 04:04 PM   #4
Mr. Detail
Scottwax's Avatar
Manual says every 105k miles. A couple Honda techs I've talked to say as long as you don't go past about 120k miles between changes you should be fine.
Old August 30th, 2015, 03:43 PM   #5
hometheaterman's Avatar
105k is a good interval. That said, I've gone to 120k on mine without a problem, but just because I got lucky doesn't mean you will.
hometheaterman is offline   Reply With Quote Quick reply to this message
Old October 13th, 2015, 05:47 PM   #6
I'm at 110k, probably should get mine done
darsh09 is offline   Reply With Quote Quick reply to this message
