Side engine mount stripping? - Honda Accord Forum : V6 Performance Accord Forums
Old September 7th, 2015, 01:51 AM   #1
Strath's Avatar
2003 ex-l v6 5at sedan
Has anyone else had an issue with the side engine mount stripping out? And the piece that I am needing to replace is the part of the mount attached to the engine. Are there any guides on this? Or part #'s? Can't find what I need on any schematics.
Strath is offline   Reply With Quote Quick reply to this message
Old September 7th, 2015, 07:16 AM   #2
On the motor side or on the frame? Motor one can be replaced
Old September 7th, 2015, 11:46 AM   #3
accord325's Avatar
I believe you are referring to the bracket(?) that the mount attached to? So there is the actual mount but then a bracket piece that attaches to the passenger side of the engine block. If you stripped a bolt out then there is no replacing, the block is what is actually stripped. There are two small bolts and one long. I installed the long bolt in the wrong location and did the same thing. Luckily the other two are holding well. You referring to #6 in the diagram? #6 is what Im speaking to
2006 Honda Accord 2 Door EX (V6) KA 6MT Engine Mounts (V6)
Maybe it's #4, #6 looks to be the front bracket. I actually dont see it, but its similar to #4 and #6
Old September 7th, 2015, 12:25 PM   #4
Strath's Avatar
If anything it'd be what the #5 in that diagram, or what that bolts into.
Old September 7th, 2015, 07:37 PM   #5
The Jester
If it's the part i'm thinking of, the bracket that bolts to the engine, I think I have an extra laying around. I misplaced it and needed to rebuild, can be refound if it's needed probably.
Old September 8th, 2015, 12:06 PM   #6
Strath's Avatar
It is the bracket that bolts to the engine. U have a part # by any chance? Can't find it on any diagrams
Old September 8th, 2015, 12:35 PM   #7
bozos_si's Avatar
I might have that piece at home.
Old September 8th, 2015, 12:41 PM   #8
Strath's Avatar
If anyone does have it I'll buy it off you I suppose.
Old September 8th, 2015, 01:29 PM   #9
The Jester
Let me see if I actually tossed it, or if I tossed it into a pile somewhere. Might give you a reason to come up into town, unfortunately when the car is down but ah well.
Old September 8th, 2015, 02:12 PM   #10
Strath's Avatar
Oracle, where are you located again?
Old September 8th, 2015, 03:09 PM   #11
bozos_si's Avatar
manual and auto use the same mount correct?
Old September 8th, 2015, 04:46 PM   #12
Strath's Avatar
No idea
Old September 9th, 2015, 05:32 AM   #13
bozos_si's Avatar
I coudlnt find it. sorry.
Old September 9th, 2015, 06:29 AM   #14
Strath's Avatar
All good, thanks anyway bro!
Old September 9th, 2015, 05:59 PM   #15
Strath's Avatar
Does anyone know the part # by any chance?
Old September 10th, 2015, 04:50 PM   #16
The Jester
North of you lol.
Old September 11th, 2015, 03:19 PM   #17
Strath's Avatar
I'm in the south. Everyone is north of me. Lol
Old September 12th, 2015, 11:19 AM   #18
Strath's Avatar
Spent a good hour last night looking thru schematics for the part #. Can't find it. If anyone who has purchased this part before can link the number that'd honestly help a ton as I'm stuck right now.
Old September 13th, 2015, 07:30 PM   #19
It says right on that page with the part number: 50620-SDB-A00
I wonder if you even looked. And I'm wondering how you stripped that out. I've taken that off and put it back on at least 5 times with no issues. All 3 bolts have large thread pitch.
Old September 15th, 2015, 01:24 PM   #20
Strath's Avatar
That isn't the correct part, that part isn't stripped it's the one it bolts into that's stripped. I believe it stripped because I had issues when I last changed the side mount with getting the engine to elevate properly. Took it off this morning, front thread is gone, rear is good. Cleaned up everything with a wire wheel and bolted it back together, it's actually holding it for now with just the 1 screw. Pictures attached, the piece which is attached to the mount in the photo is the only part I can find, I need the piece that it bolts onto. Second image is the piece I need.
Side engine mount stripping?-0915151000b_1442341427376.jpg   Side engine mount stripping?-0915151000_1442341456607.jpg
Old September 15th, 2015, 01:57 PM   #21
you can actually replace that on the engine side. It comes off when you do a timing belt.
Old September 15th, 2015, 04:56 PM   #22
The Jester
Another common option is to just drill the threads out one size up and either tack weld a nut on there or simply hold the nut in place when you bolt it up.
Old January 2nd, 2018, 09:52 AM   #23
Side engine mount bracket replacement
So sorry for reviving this thread - But, I'm about to go nuts
I found the part number (2004 Accord V6 with Auto trans) 11910-RCA-A00 Bracket, Engine Side Mounting (its in the oil pan picture)
My dumb question is - Can i replace this without removing the lower timing cover??
Someone stripped the bolts that go to the passover bracket going to the engine mount itself, they were nice enough to Heli-Coil it for me but while trying to figure out a power steering issue (another thread) i found out the bolts wont even hand tighten down and the holes are completely stripped...The heli coil is wrapped around the bolt I pulled out of the hole that were rattling around in there...
Sorry for being lengthy, I just want to see what I'm up against - I want to replace it but dont have the place, time, or tools to pull it off if the lower timing cover and everything has to be removed. So for anyone that's done it what did it entail?
Jasondt2001 is offline   Reply With Quote Quick reply to this message
Old January 11th, 2018, 01:36 PM   #24
steve4748's Avatar
My 05 v6-6 ripped the driver engine mount apart at the rubber. my engine slapped the hood when id accelerate hard lmao. fixed now tho
steve4748 is offline   Reply With Quote Quick reply to this message
