Help please! Engine rev high but no speed gain - Honda Accord Forum : V6 Performance Accord Forums
Old October 8th, 2015, 07:36 AM   #1
Working on it
NickkxO's Avatar
Send a message via AIM to NickkxO Send a message via MSN to NickkxO
Exclamation Help please! Engine rev high but no speed gain
Hi guys,
Yesterday I was driving and came to a stop and all of a sudden my 03-AV6 started to acting up. When I drive in first gear at local the rev goes up to 2-3k then shift into 2nd gear and after that when it speed hit up to 20-30 mph and rev goes to 2-3k again at 2nd gear the rev will shoot up and the speed won't increase. It feels like the car is in neutral that it revs but no increase in speed. Also I noticed that it takes forever to change from Reverse to Drive mode. I have to hear a click sound before the car will actually move, and the time gap between Reverse and Drive is pretty long...like 5-10 seconds. I have no idea what is going on. Anyone have this problem before please chip in.
Thanks
NickkxO is offline   Reply With Quote Quick reply to this message
Old October 8th, 2015, 07:56 AM   #2
Calm like a bomb
StevilKnievel's Avatar
Sounds like your torque converter might be taking a shiz. Those are symptoms of low pressure as well. Check your fluid levels and see if the problem repeats in the same manner.
Old October 10th, 2015, 11:46 AM   #3
Check your oil. Mine did that I drink an 02' AV6
Sent from my SM-N910T using Tapatalk
fkkb is offline   Reply With Quote Quick reply to this message
Old October 10th, 2015, 06:04 PM   #4
The Jester
Your transmission is shot, sorry bud. That long change is a dead giveaway. One day it'll just crap out and lose all power while driving so fix this proactively.
You can try getting a cooler on it and a magnefine filter to prolong its life, but that's just hospice.
Old October 13th, 2015, 11:22 PM   #5
Mr. Detail
Scottwax's Avatar
If the fluid level is full, then you likely having internal issues that will require a rebuild.
Old October 14th, 2015, 12:21 PM   #6
Working on it
NickkxO's Avatar
Yeah I noticed the fluid is enough so it definitely an internal issue. What I'm thinking right now is either have it rebuild or just swap a manual tranny. I'm having trouble finding the posts about the manual tranny swaps. Anyone know how much would it cost to swap in a manual tranny?
Old October 15th, 2015, 12:41 AM   #7
The Jester
3-5k is what I've been able to get quotes for depending on what you already have and what the shop is willing to work out with you.
Alternatively another automatic is in the area towards triple digits.
Old October 16th, 2015, 08:03 AM   #8
salcuta88's Avatar
03 V6??? Bad tranny. Sorry. Buy an used one that was taken off an 05 Accord. No reason to spend $3000. You could get it replaced for half the price.
salcuta88 is offline   Reply With Quote Quick reply to this message
Old October 16th, 2015, 07:40 PM   #9
The Jester
Did you even read the post above you?
Also, 05 won't be any better except for that squirter TSB. Which will be on most 03s if theyre alive today anyway.
Old October 16th, 2015, 08:53 PM   #10
salcuta88's Avatar
Actually, the 2005 V6 trannies are better.
Lower failure rate
Old October 22nd, 2015, 12:14 AM   #11
The Jester
Lower failure rate
Due to the transmissions not having miles put on them without the squirter.
Old October 28th, 2015, 12:13 PM   #12
Working on it
NickkxO's Avatar
Decided to get the tranny rebuilt, then see from there if anything just sell the car.
Old November 1st, 2015, 05:00 PM   #13
ye he is right
desiredkarma is offline   Reply With Quote Quick reply to this message
Old November 2nd, 2015, 01:00 AM   #14
FollowingNFront's Avatar
I dont think that is accurate. My old 06 was about to have its second tranny give out at 89k miles
FollowingNFront is offline   Reply With Quote Quick reply to this message
Old November 2nd, 2015, 05:40 AM   #15
salcuta88's Avatar
It is. Do some statistical research.
Did you ever replace your atf? How were your driving conditions.
All cars will have a bad tranny here and there.
Old November 2nd, 2015, 09:23 AM   #16
Lol, do some statistical research, lol....
Look at my post count... Im fairly knowledgeable on the 7th gen AV6. I did quite a few D&Rs on my transmissionS and I did my research...
I even made threads about it back when it was happening. My stories are documented somewhere on this site
Old November 2nd, 2015, 09:28 AM   #17
salcuta88's Avatar
Nice! I haven't looked at your profile. Not saying 2004-2005s are bulletproof, but 2003 was the worst and much more unreliable than 04-05.
Old November 2nd, 2015, 09:52 AM   #18
No problem. Im just pretty sure that there were no mechanical differences. Even 06 (which mine was) and 07s had failures. As well as Acura TLs, Honda Pilots, Acura MDXs, etc.
Old November 2nd, 2015, 10:20 AM   #19
I think there were slight revisions made in attempt to make the transmissions more durable but still nowhere near what they needed to be sadly. FnF you back for good though? I thought I saw a ghost when I saw you post your Nissan for sale haha.
Nickdees is offline   Reply With Quote Quick reply to this message
Old November 2nd, 2015, 10:53 AM   #20
Im not back for good yet. I have to see what route Im going to take yet. If I sell the Nissan though, there is a good chance I will be back in an AV6
