S2k tranny - Honda Accord Forum : V6 Performance Accord Forums
Like Tree2Likes
  • 2 Post By toinkee69
Old October 20th, 2015, 11:04 AM   #1
S2k tranny
I've been hearing rumors that the Honda S2k Transmission can bolt up to one of the J series motors with little to no modifications. Are those rumors true or even slightly true?
D'sean_CM8 is offline   Reply With Quote Quick reply to this message
Old October 20th, 2015, 01:25 PM   #2
Take a look at a J-series tranny and an S2000 tranny and you tell me
Achmiel is offline   Reply With Quote Quick reply to this message
Old October 20th, 2015, 02:21 PM   #3
Bobby Lane Racing
nighthawk04v6's Avatar
yes it bolts right on. how many bolts?
Old October 20th, 2015, 02:31 PM   #4
05accord6spd's Avatar
When i did my rear wheel drive conversion i only used like 5-6 bolts its really simple.
Old October 22nd, 2015, 12:13 AM   #5
The Jester
Hey, hey, now it is possible. But it's to the 6th gen or DBC j series, and not without modifications. It's also a very small knowledge base, you'll have to find one of the forums that has data on this for any hope of doing it successfully. S2k forums, and I hear there are some miata forums have data on this.
Old October 22nd, 2015, 04:36 PM   #6
JDM UC1
toinkee69's Avatar
i did an LS swap on my sedan and used an s2k transmission, anything is possible and the transmissions universal.
nighthawk04v6 and Nickdees like this.
Old October 22nd, 2015, 04:51 PM   #7
Bobby Lane Racing
Lsvtec?
Old October 22nd, 2015, 05:13 PM   #8
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
I'm no expert but....
S2k tranny will have a "yoke" coming out the rear of that tranny case for the driveshaft, since the S2k is rear wheel drive.
The Accords are front wheel drive and the tranny case, wether it be auto or manual, has driveshafts coming out both sides of the tranny.
The Miata guys can use the S2K tranny because, they are rear wheel drive.
huge difference, I'm going to say a Big NO.
Old October 24th, 2015, 01:41 AM   #9
The Jester
Pretty much. Some swapped civics too but, rwd.
Old November 18th, 2015, 10:55 AM   #10
will's Avatar
I've seen videos and pictures of a j37 swapped s2k. I'm not sure if it is still using the stock trans and even then I'm not sure the j37 and j30 have compatible transmissions
will is offline   Reply With Quote Quick reply to this message
Old December 6th, 2015, 11:59 PM   #11
sds
It'll bolt to the Miata trans, and HPD/Honda have done a J37 S2000.
sds is offline   Reply With Quote Quick reply to this message
