Phone Mount or GPS Mount for 7th Gen - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By StevilKnievel
Old January 28th, 2016, 12:31 AM   #1
Not sure where to post this, but wondering if anyone had pics or ideas for their GPS or Phone Mount. I've bought the suction cup ones from eBay and they suck.
Our dash slants a bit, so I'm wondering what you guys have setup.
Will need to either buy a GPS or Google Maps.
Btw, is fixing the cigarette lighter a challenge? Seems like mine doesn't work?
Thanks
Battery is offline   Reply With Quote Quick reply to this message
Old January 28th, 2016, 12:40 AM   #2
Honda enthusiast
michaellowrider's Avatar
I put mine in the cubby. I put the disc the suction cup sticks to on the left inside wall of the cubby. Works great with my garmin and is not a blind spot.
Old January 28th, 2016, 04:58 AM   #3
Domi_no's Avatar
I use the holder that slide into the CD slot. Works okay, but it blocks the volume dial. Not a big issue considering I mostly use the steering wheel controls. Not sure of about the cigarette lighter. Check to make sure there is no debris in it that caused a short, then check the fuse.
Old January 29th, 2016, 01:27 AM   #4
You guys got pics?
For those that mount, any ideas? thanks!
Old January 29th, 2016, 01:48 AM   #5
Btw, has anyone replaced their 12 V power outlet?
Anyone know where the fuse is related to that?
Old January 29th, 2016, 09:21 AM   #6
Calm like a bomb
StevilKnievel's Avatar
Kudausa.com The best you can find for 7G. Very high quality.
Domi_no likes this.
Old January 29th, 2016, 10:04 AM   #7
accord325's Avatar
you can see where I put mine a long time ago. Works well and was a clean look. I ran the cord under the seat and mat, then up the pillar.
https://www.youtube.com/watch?v=Z9iykH5vPDc
Old January 31st, 2016, 11:13 AM   #8
accordcoupe7's Avatar
Send a message via AIM to accordcoupe7
Use 3m magnet and stick it to my dash
accordcoupe7 is offline   Reply With Quote Quick reply to this message
Old February 1st, 2016, 01:10 AM   #9
Thanks i'll inquire. seems like they make it for iphones. but i'll see.
thanks!
Old February 1st, 2016, 01:11 AM   #10
Do you know where the fuse is located? I cleaned it out, and will test it.
Old February 1st, 2016, 06:17 AM   #11
Domi_no's Avatar
The fuse box is under the dash, driver side, forward of the front door, just above the hood release, above the dead pedal. The cover slides towards you, and will have the fuse location on the inside of the cover. It should show #9 for 'Front Accessory Sockets' with a 15 amp fuse. If this is what you see, then it's the bottom row, third from the right (or 9th from the left.)
Old February 3rd, 2016, 04:45 PM   #12
Mr. Detail
Scottwax's Avatar
Original owner had a phone hard mounted, just attached a new holder to it.
&mpt=[CACHEBUSTER]">
Old April 30th, 2016, 02:50 AM   #13
I just noticed that the car charger in the dash and in the compartment between the seats do not work. Could this be a fuse issue or multiple fuse?
Basically the charger in the dash by radio and the one in the compartment BOTH do not work.
Any ideas? thanks.
