My door will not open from the inside and outside [emoji33][emoji24] - Honda Accord Forum : V6 Performance Accord Forums
Old March 26th, 2016, 10:50 PM   #1
accordcoupe7's Avatar
Send a message via AIM to accordcoupe7
As the title states my door will not open at all from the inside and outside. I just closed the door and when I got to my destination and tried to open the door it would not open. I rolled down the window and tried to open from the outside still nothing. I have to see what happened on the inside but I can't remove the door panel without opening the door. Suggestions?
accordcoupe7 is offline   Reply With Quote Quick reply to this message
Old March 27th, 2016, 03:02 AM   #2
Honda enthusiast
michaellowrider's Avatar
This happened to me one time...you can get the door panel off but it's a struggle. Take out the screws that hold the panel and get a really good grip and pull, it will eventually pop off then you can open the door by manually actuating the latch mechanism.
Old March 27th, 2016, 08:00 PM   #3
Got it done. Thanks for the help
Old April 26th, 2016, 09:30 AM   #4
NightHawk Gal's Avatar
Glad you got it fixed! What happened on the inside that made the door not open?
NightHawk Gal is offline   Reply With Quote Quick reply to this message
Old April 26th, 2016, 02:19 PM   #5
dont deviate
htekken's Avatar
Thats very odd that neither door handle worked.
htekken is offline   Reply With Quote Quick reply to this message
Old May 1st, 2016, 09:46 AM   #6
The green plastic broke for the door opener
Old May 2nd, 2016, 09:37 AM   #7
Calm like a bomb
StevilKnievel's Avatar
Mine is broken as well but I was still able to open from the outside. As far as I know, those things aren't replaceable. You have to replace that whole cable mechanism because there is no cut-out to snap it on and off like almost EVERY OTHER CAR IN THE WORLD. I just dabbed some super glue on it and a bit of duct tape to hold while the glue cured and haven't had a problem with it since then. Though I did enjoy Bo Dukin' in and outta the car for a while.
