Weird abs tcs ebrake battery transmission problem - Honda Accord Forum : V6 Performance Accord Forums
Old May 16th, 2016, 03:03 AM   #1
Hey guys, i tried searching i find all these problems separately but not all at once.
so the other day i was changing out my A/C fuse to see if that was why the compressor wasnt coming out and when i finished up and started the car all these lights(minus the maintenance required) came on. its the tcs, abs, brake, check engine, and the D is flashing a green light. the battery light also comes on about 5 minutes after the car starts. Also the radiator fan wont stop running after the car is turned off for about 15 minutes or so.
i didnt touch anything relating to any of those that i can remember. i also charged and used a different battery just in case and nothing. i have no idea what is happening. only thing i can think of is the ecu is fried. anyone experience this before?
Thanks in advance!
javskies is offline   Reply With Quote Quick reply to this message
Old May 16th, 2016, 05:24 AM   #2
M90SC Boosting 13PSI
NVA-AV6's Avatar
There is a ECU fuse in that fuse box as well as in the drivers foot well box, I would just start going thru ALL of the fuses in the under hood box.
