Lightweight battery options? - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By accord325
Old May 30th, 2016, 05:51 PM   #1
ChrisQ80's Avatar
I was considering relocating my battery to the trunk on my 6-6 coupe, then the idea of a lightweight battery came to mind instead. I found this, but Im not sure on fitment, or if its powerful enough.
http://www.jegs.com/i/Braille-Batter...B2015/10002/-1
ChrisQ80 is offline   Reply With Quote Quick reply to this message
Old May 30th, 2016, 07:10 PM   #2
pa1nt13aller's Avatar
I just went with the 4 cylinder accord battery. Almost half the size of our stock one and 500CCA
Old May 30th, 2016, 08:43 PM   #3
The Jester
Amazon.com: Battery Tender BTL35A480C Lithium Iron Phosphate Battery: Automotive
The car can start off of a LiPo battery used for RC cars, ran it for about a month. Ran a smaller one of these for a month, until my trunk got to a ridiculous temperature (likely near 200*) and it blew out the bottom. Given I had already shorted the thing out so many times it was leaking, but still. theres a risk with them, but theyre the strongest batteries per weight out there. If cost isn't a huge thing, get 2 of the 1 size smaller ones and line them up. Should be around 30Ah and 700CCA
Old May 31st, 2016, 03:01 PM   #4
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
If you get a Braille, you may want to invest in a battery tender/trickle charger. That is to keep it charged at 100%.
Do some research to get more details.
Old June 1st, 2016, 02:53 PM   #5
accord325's Avatar
7 lb Optima Battery for Toyota Prius. Required spacers on the terminal, I just cut old terminals and wrapped them around the ones on the battery.
pa1nt13aller likes this.
