Tl ecu - Honda Accord Forum : V6 Performance Accord Forums
Old November 9th, 2017, 09:16 PM   #1
Tl ecu
for my 04 6-6 i would need a tl ecu
04-05 only
Repin 3 wires
Other than that itll plug in
But to play i would have to reprogram ecu to read the key
But if im able to get a tl ecu that comes with the matching key and ignition then im all good to go right? Or even a matching key and ignition that comes with the ecu still not work?
530av6 is offline   Reply With Quote Quick reply to this message
Old November 9th, 2017, 10:03 PM   #2
I can’t reprogram the ecu to match the immobilizer. Pm me for details
Old November 10th, 2017, 03:44 AM   #3
Im just trying to ask if its unnecessary to reprogram the ecu if the ecu comes with a matching key and ignition. Or will it still fail regardless
I found a good deal i suppose for the 04-05 tl manual ecu with a matching key and ignition so im very curious
Old November 10th, 2017, 10:03 AM   #4
If they all Match it won?t need to be program, but if you do emission via obd2 port. You are going to have issue since the vinn won?t match up.
Old November 12th, 2017, 02:23 AM   #5
So all my door locks and alarm would still be functional too tho right? I would just have to use the tl key to start the car.
Old November 12th, 2017, 10:48 AM   #6
You will have to redo the door remote, but that is easy there is a YouTube video. It?s been done plenty of time already.
