installing Transmission Temp Gauge help - Honda Accord Forum : V6 Performance Accord Forums
Old December 27th, 2017, 09:39 PM   #1
i've never seen a write up for a Trans Temp Gauge and it wasn't too expensive - $50ish shipped
my main concern is it like drilling into an Oil Pan for a Oil Temp gauge or is there any areas i need to avoid?
hoping its a straight forward install and any help is appreciated
install on: 03 - Accord - 4 Dr. - Auto - V6
Old December 27th, 2017, 10:37 PM   #2
You can run a t from one of the cooler lines.
Also are you looking for a way to tune your car? I have an aem fic that will help
Old December 28th, 2017, 03:55 PM   #3
ok thanks thisaznboi88 as always
hm...i will PM you
Old December 28th, 2017, 11:39 PM   #4
Putting it in the trans cooler line works ok IF it is in the hot/oil out line & not the colder/return line. Also be sure you allow full oil flow thru whatever fitting you mount the sensor in.
My (old school) method for mounting a temp sensor into an engine or auto trans steel pan is to braze a steel adapter fitting in. Brazing is an old time process but is ideal for this type of work. For any pipe thread sensor or bulb type mechanical gauge use a suitable size steel threaded pipe bushing or half coupling.
I have also used 1/2"-20 hex nuts on pans to add a new drain plug. Works perfectly with 1/2" ID gasket and either a short bolt or "Help" 1/2-20 drain plug.
My old '81 big block Suburban had both trans & engine oil temp gauges.
Gold Country is offline   Reply With Quote Quick reply to this message
Old January 14th, 2018, 10:07 PM   #5
can someone let me know where would be the best spot for the hot/oil out line & not the colder/return line and if i can use the Trans Warmer...which hose?
i was told i could also use the T adapter onto a Radiator hose
any help is appreciated as i couldn't find a detailed answer even using search
Old January 16th, 2018, 03:38 PM   #6
i did find this in the Service Manual for 4 cyl. but not for V6 even in the Service Manual V6 Supplement:
Old February 2nd, 2018, 07:27 PM   #7
finally got the part Calamity Coyote on DA recommended...cost was $45 w/tax, list price was $60ish. paid out of pocket $20 bucks because Mile High Honda was nice enough to send me a $25 gift card
