doing DA t-rd's V6 transmission cooler install - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By 2i2dk1ny2i3
Old April 13th, 2018, 09:02 PM   #1
almost have everything ordered or delivered:
1. B&M 70264 transmission cooler - in pic
2. 1 qt. of OEM Honda DW-1 transmission fluid
already got a case
Tools needed:
3. got these 3 already
- 17mm, 3/8" drive socket
- 3/8" drive ratcheting wrench
- 3/8" drive extension, at least 1 foot
- Straight + 90 degree + 45 degree needle nose pliers + 3/8" hose removal pliers
these aren't a everyday tool for me nor used often so i picked all 3 at Harbor Freight for around $20
4. 3/8" ABA hose clamps - in pic
5. Silicone spray - in pic
6. - 3/8" HVAC foam tubing - in pic
7. - bunch of medium length zip ties - if you look in the 3rd picture, i live in CO which has true 4 seasons and overtime, Zip Ties tend to become brittle and break...i'm going to try these velcro cable ties and will report back
8. Astro 9409A remote hose clamp pliers - i'm glad i asked t-rd about this tool because its like $45 bucks and what he said during his install, it seems necessary to make Install a lot easier
9. Additional 5 feet of 3/8" Goodyear transmission fluid hose. I bought 5' from Advanced Auto for about $10: this is my biggest problem and if anyone can help with alternative...for some reason i can only find it sold by 25 ft. and cheapest like $50...anything else i could use that would be as good as goodyear?
10. Permatex blue loctite - going to hold off on this for now
any help or suggestions for an alternative to Part 9 is appreciated
Scottwax likes this.
Old April 14th, 2018, 06:13 PM   #2
this is what I put on my car:
http://derale.com/products/fluid-coo...-cooler-detail
mounted it right to to bottom of the battery tray. I think I ordered hose from Summit maybe, can't recall.
When buying from Advance Auto, if you google "discount codes" and order online to pick up in store, you can usually get 30% off...
I could be wrong, but that small stock "cooler" will also help warm the fluid in cold weather with the coolant running thru it. That's why I went with the small heat sink. Either way,I guess it can't hurt to increase the amount of fluid in the transmission.
booley is offline   Reply With Quote Quick reply to this message
Old June 18th, 2018, 12:25 AM   #3
hm, that one looks much more compact...thanks for posting
i may have to go with your style due to space behind the Front Bumper and lighting
