2007 Accord V6 6 speed RPM Issues - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By blkcoupe03
Old February 22nd, 2019, 12:33 AM   #1
sicksix
okimports's Avatar
Can someone check out my obd2 readings from a recent drive? I am runner by pretty rich and my rpms are up by around 500 to 1k!
https://youtu.be/U0uTKe_eY8E
okimports is offline   Reply With Quote Quick reply to this message
Old February 23rd, 2019, 02:33 PM   #2
sicksix
okimports's Avatar
Bump.. Can someone help?
Old February 23rd, 2019, 03:36 PM   #3
What issues is the car having? I know you said you're running rich but is the car doing something weird or is there a check engine line or anything else?
blkcoupe03 is offline   Reply With Quote Quick reply to this message
Old February 23rd, 2019, 07:47 PM   #4
sicksix
okimports's Avatar
Well originally what happened was that I blew a spark plug on cylinder 6 and so replaced the spark plug and coil that was bad! It stripped the threads so had to get one of those retread kits! Anyway after fixing that, I feel like I have less power! When I am driving, I get up thru the rpms a lot faster and I know itís not because I am going faster! My rpms seem to be around 1k too high as I am driving, no codes thrown or anything like that but worried it is my cats or o2 sensors?
Old February 24th, 2019, 07:52 AM   #5
Try checking for a vacuum leak somewhere. I had a car once that had a similar issue that the RPM's seemed higher than normal and it turned out to be a vacuum line and a very small leak around the intake manifold.
okimports likes this.
Old February 25th, 2019, 10:01 PM   #6
sicksix
okimports's Avatar
I am going to try your ideas thank you for replying! I looked at my air intake hose and there was a crack in it towards the connection to the engine so I just swapped that out and noticed the car is running richer now which I can only assume because the computer has not compensated for the change yet! I left the negative battery terminal off for about 5 min but still doing the same! Crank pattern learn and idle learn in order?
Old February 26th, 2019, 09:57 PM   #7
Did you ever find out the reason why your spark plug blew out?
Old February 27th, 2019, 12:59 AM   #8
sicksix
okimports's Avatar
No I have not! I assume itís like the issue they were having with cylinder 5 blowing!
Old February 27th, 2019, 09:01 AM   #9
I'm at a lost now. The only other things I would check is compression on each cylinder just to make sure that the #6 spark plug didn't create more issues than just the spark plug. And maybe possibly check your timing. Could be a possibility that it has jumped timing. I don't know at this point, I'm just throwing stuff out there to check. Sorry I can't be much help but maybe someone else could shed some light.
Similar Threads
Thread Thread Starter Forum Replies Last Post
6 Speed Obsession (Swap info and harness) Richie V6 6TH GENERATION HONDA ACCORD (1998-2002) 3082 February 28th, 2017 11:56 PM
Currently testing E85 fuel on stock ECU on 03 accord v6 6 speed AccordingLO 7G HONDA ACCORD PERFORMANCE DISCUSSION 72 June 21st, 2012 01:05 PM
Video 03 accord v6 6 speed vs 06 350z 6 speed AccordingLO GENERAL AUTO DISCUSSION 34 September 29th, 2008 05:55 PM
Installing backup camera on 2007 Accord sedan brycerocket 7TH GENERATION HONDA ACCORD (2003-2007) 11 May 21st, 2008 10:35 PM
2006 - 2007 Honda Accord Coupe Accessories and Electronics sy272004 CLASSIFIEDS 2 December 16th, 2007 11:48 AM
