High Beams/Fog Lights - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 8TH GENERATION HONDA ACCORD (2008-2012) > 8G HONDA ACCORD EXTERIOR/INTERIOR MODS
Old May 26th, 2008, 02:05 PM   #1
Senior Member
chaqui74's Avatar
I would like to have my foglights on with out my headlights been on is it possible? What about when we put the high beam and the fog lights turn off is there a way that they woun't turn off ?
Old May 26th, 2008, 03:01 PM   #2
ELP_JC
Guest
Posts: n/a
The car's electrical system was designed that way; I wouldn't mess with it.
I know for a fact fog lights and high-beams are illegal in most states (why? I have no idea; makes no sense), so all auto manufacturers wire them to turn off, at least in the US. However, some cars allow you to turn the fogs on with the parking lights, like my GTO, but most Japanese cars I've owned didn't do it. I'm sure it could be done, but why risk frying something, or voiding your warranty just for that? Your call. Later.
JC
Old May 27th, 2008, 10:46 PM   #3
mattchatwin's Avatar
Only way to do it is to rewire, can't use the stock switch as there is a relay system built into it. On my civic I rewired it using my own relay and the switch powered off of the cigarette adapter so that they turned on when the switch was on and only got power when the car was on. I just used a lighted rocker switch, a relay and good wiring with a 20A fuse, direct power from Battery. Most audio shops will even do it for you if you pay a guy on the side.
mattchatwin is offline   Reply With Quote Quick reply to this message
