Bolt on Acura ZDX manifold and TB on 8th gen Accord - Page 2 - Honda Accord Forum : V6 Performance Accord Forums
Go Back   Honda Accord Forum : V6 Performance Accord Forums > CAR SPECIFIC DISCUSSION > 8TH GENERATION HONDA ACCORD (2008-2012) > 8G HONDA ACCORD PERFORMANCE DISCUSSION
FAQ Members List Calendar Mark Forums Read Insurance
LinkBack Thread Tools
Old June 16th, 2019, 10:50 AM
my blue coupe's Avatar
just did this swap on a 2015 coupe. There are a couple things that you change to make this work. Anyone doing this swap on 8th gen. i will explain/show what i did. you will need to change the purge valve set up. our stock purge valve solenoid has a diameter with an o ring that fits in a hole in the manifold by the throttle body. New manifold doesnt have this hole in it. The make the same purge valve,only it has a hose barb intead of diameter an o ring. Then you can run hose to fitting on top of manifold. Like i said there a a few things that may throw you,but hit me up,i can explain what i did.
my blue coupe is offline   Quick reply to this message
